2013 Terex PT110 Forestry
   / 2013 Terex PT110 Forestry #42
I have a PT 110 and I just want to know why the air conditioning not working while under load. Any solutions?
   / 2013 Terex PT110 Forestry #43
Did you find the problem with the A/C unit while under load? Im having the same issue with mine right now.
   / 2013 Terex PT110 Forestry #44
Why, when I hook a CAT BR166 Brush Cutter that is 5.3 -21.1 gpm into the machine, the A/C units starts to blow hot air into the cabin. Any suggestions?
   / 2013 Terex PT110 Forestry #47
Anybody had any issues with this hose?I have blown two in the last 18 months,Seems the hose straightens under pressure putting pressure on the steel elbow.The pipe always goes on the seam on the elbow.$1k nzd from the dealer for the terex part.
   / 2013 Terex PT110 Forestry #48
Usual response I am the only one with a problem from the dealer.I have cut the pipe off tig welded a fitting to the block and run all hose.
You're not the only one. I'm on my third.
   / 2013 Terex PT110 Forestry #50
Mate, you probably get a better response on www.heavyequipmentforum.com . There's plenty of owners, operators and fixers there.
How long is the ASV parts warranty?
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2016 Chevrolet Caprice Sedan (A55758)
2016 Chevrolet...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A55788)
2013 Mitsubishi...
Kubota KX080-4 Excavator Cylinder (A50775)
Kubota KX080-4...
