2014 Chevy/GMC specs
   / 2014 Chevy/GMC specs #92
I agree. The DMax has earned a good reputation in the HD pickup world and deservedly so. It is a good engine, a medium duty truck engine, that makes good power, has been pretty reliable and delivers good economy. Just as it was a mistake for Ford to dump Internationl for their Diesel engines in my opinion, it would be bad for GM to dump DMax even though they own a majority stake in the company now. For a lot of people the ability to have a true medium duty truck engine that was made by an engine builder instead of in house is a huge selling point. I know after my experience with GM's 6.2 liter diesel I will never own a diesel truck whose engine was not designed by a dedicated Diesel engine producer.
In house may have been a bad thing for GM in the 80's its the right move for Ford to part ways from International. The new Ford diesel is hands down better.
Chris
   / 2014 Chevy/GMC specs #93
Sounds like they've got the bugs out of the 6.2 ?, Don't believe Ford and the 6.0 are there yet ... Hopefully they will get a solid fix.. Also I was under the impression the only engine ranked as medium heavy duty was the Cummins with a 350,000 to average rebuild?
I know a guy that got 475, 000 out of a 7.3 in a rollback.
   / 2014 Chevy/GMC specs #94
   / 2014 Chevy/GMC specs #95
Yeah- the wife and I got a ride back in one of those (ride of shame ) trips when the water pump puked its seal at 103,000 on the (Dodge -it was on the roll back) got to say, I liked the sound of that engine, guy said they really like the 7.3 and spec out all their new trucks identically, no major problems to report... In the dodges defense, I did hear a change in the sound of the serpentine belt about a week before it broke, and it was the only disabling event since new.. Also only $55 water pump plus antifreeze. I stand corrected on the medium duty, but are any of the new diesels ,used in GM, or Ford products medium heavy duty ?
   / 2014 Chevy/GMC specs #96
Chris
Based on my experience I would disagree that in house is better for HD diesel pickups. Although I am starting to think that many of the problems Ford has had with their diesels has been the fault of Ford and not International. In my recent search for a new diesel pickup I've test driven all the big 3 and spent a bunch of time on the forums associated with each brand. While by and large most people are happy with their Powerstrokes there is a growing number of people having catastrophic failure with their 6.7 Powerstrokes. Apparently the CP4 common rail injector pump is even more sensitive to water than the CP3 used in the previous generation LMM Duramax as well as the current and previous Cummins. Ford's water separation system is apparently not doing a good enough job and a lot of CP4 pumps are biting the dust resulting in $12000+ worth of repairs that Ford will not honor under warranty. There is enough of a problem that people are getting a class action lawsuit together.
The solution seems to be additional water separation, fuel filtration installed prior to Ford's setup. Apparently dieselsite is selling so many of their setups that they are perpetually out of stock. These systems aren't terribly expensive but seem to work very well and this reportedly may be THE fix. I know if I had gone with a Ford, I would have waited to take delivery until the dieselsite upgraded filtration system was in stock so that it would never have to depend solely upon Ford's system.
I'm sure lots of people are happy with their Powerstrokes, heck I really liked my 6.4 for the short period of time I had it. But for me old habits die hard and I swore after the last time that I was stuck on the side if the road with my 6.2 liter diesel that I would never own another in house diesel. While I have at least considered Ford's in house diesel I do consider it a major competitive disadvantage to GM and Ram. Fortunately Ford builds a great truck and has advantages over other brands in other areas so they will not have any problem selling trucks. The same goes for the other brands too, they each offer a combo that appeals to someone.
   / 2014 Chevy/GMC specs #97
I had a 7.3 Powerstroke and I would happily own another. It was a great engine that I would likely still buy if it was available today. It may very well be looked upon as one of International's all time most successful engines.
   / 2014 Chevy/GMC specs #98
The Navistar "MaxxForce7" series (aka the Powerstroke 6.4) was also a MD engine (as was the 7.3), but in that config, the 6.4 had a single VVT vs sequential turbos.
Navistar VT engine - Wikipedia, the free encyclopedia
Aaron Z
This kind of supports some of my other opinions. Even the dreaded 6.0 was a decent engine when International used it outside of Ford trucks. It was designed to run around 225 to 250 horsepower if I remember correctly. If you look at the most common 6.0 problems, outside of emissions related stuff, a lot of the head problems resulted from people running hot tunes, way over stressing the head bolts which were already supporting 325 horsepower in stock Ford form instead of the 225 to 250 horsepower which International intended.
The same goes for the 6.4 Powerstroke. It is often considered to have insufficient water separation which can cause the high pressure common rail injection pump to fail. There were also a lot of problems with radiators. These are not really International's design problems, as their engines worked well in other applications.
I really believe that International builds a perfectly fine diesel, but think Ford may have asked the engines that they picked for their trucks to do too much.
   / 2014 Chevy/GMC specs #99
QUOTE=Lt CHEG;3262015]This kind of supports some of my other opinions. Even the dreaded 6.0 was a decent engine when International used it outside of Ford trucks. It was designed to run around 225 to 250 horsepower if I remember correctly. If you look at the most common 6.0 problems, outside of emissions related stuff, a lot of the head problems resulted from people running hot tunes, way over stressing the head bolts which were already supporting 325 horsepower in stock Ford form instead of the 225 to 250 horsepower which International intended.
I really believe that International builds a perfectly fine diesel, but think Ford may have asked the engines that they picked for their trucks to do too much.[/QUOTE]
IMO International should have said "no you cant get that much power out of that engine" (in the case of the 6.0) and they should have specified how much water separation was needed on the 6.4 if that was the case. If they didn't, they are as much at fault as Ford.
Aaron Z
   / 2014 Chevy/GMC specs #100
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
NEW Woods 6ft Finish Mower (A55218)
NEW Woods 6ft...
