2014 CK2510hst more hp
/ 2014 CK2510hst more hp #1
SCWOOD
Easley S.C.
Kubota BX1800 Kioti CK2510H
Turned the fuel screw out two turns. Stock test going up my drive a 2000rpms in high with the pedal all the way down rpms dropped to 800. After the adjustment only dropped to 1200rpm.Not seeing any smoke while under load. This engine was the same in the CK27 rated at 28hp. The CK2510 was tuned to 24.5hp.I have no way of knowing how much I gained but it is noticeable.
/ 2014 CK2510hst more hp #4
Question; my CK2510H will rev past the marking for the 540 PTO revs. It will rev to 3,000 RPM. Is there a rev limiter? will operating at higher revs give me more power/fluid flow and/or pressure.
/ 2014 CK2510hst more hp #5
Also after watching tat video someone mentioned adjusting the timing> Does anyone know aboout this? My tuning experience is limited to IC engines.
2013 KUBOTA SVL 90-2 SKID STEER (A65056)
2013 KUBOTA SVL...
JOHN DEERE 260E (A68134)
JOHN DEERE 260E...
FUEL TANK WITH PUMP (A68842)
FUEL TANK WITH...
2005 MACK VISION (A67714)
2005 MACK VISION...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
