2014 emax 22 creeping forward??
   / 2014 emax 22 creeping forward?? #11
That's great! They generally try to make that sort of thing easy to ID and adjust. Thanks for reporting back and following up with pictures for future users. Most people don't think or realize what a huge help it is to report their findings.
Enjoy your weekend!
   / 2014 emax 22 creeping forward?? #12
I learned something, as I have never made the adjustment on an eMax, but have on the larger TYM models that use the accentric to make the adjustment.
   / 2014 emax 22 creeping forward?? #13
Any more info on this? I was about to adjust mine because my tractor will creep forward, but then randomly it won't. It seems like the problem is actually that the valve is not always returning to center. What is odd is, even if I use reverse and let off it will creep forward. Sometimes, for maybe 20 minutes at a time it will work properly and center-stop. This is a 2014 bought emax22 hst.
   / 2014 emax 22 creeping forward?? #14
I had an issue with my emax that was caused by a c clip on the pedal linkage. The clip came out of the groove on the pedal pivot shaft allowing the linkage to come off the guide that returns the pedals to the neutral position. Easy fix though, might be worth checking.
   / 2014 emax 22 creeping forward?? #16
If your E max has a backhoe and loader you must make sure the frame bolts are tight. Creep adjustment is made by the link between the pintel lever and the pedal linkage. You must remove top tunnel cover to access linkage.
   / 2014 emax 22 creeping forward?? #18
Had the "creep" on my 2014 emax 22 and adjusted it numerous times. However using the backhoe for a period of time would still cause the drive wheels to creep despite all the adjustments. For a different problem I had the tractor looked at by the dealer. They happen to ask me if I had experienced creeping and the tractor came back with what they called a "neutral kit" they said would correct this problem. They said emax's with backhoe had to have this retrofit. Haven't used the BH enough yet to see if the creeping is totally resolved but you may want to check it out with your own dealer.
   / 2014 emax 22 creeping forward?? #19
Any chance you have the part number of that return spring? Mine flew off yesterday.
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2024 40 ft. High Cube Shipping Container (A53117)
2024 40 ft. High...
JLG 1255 Telehandler (A53473)
JLG 1255...
2015 DODGE RAM...
TMA (A49461)
TMA (A49461)
2008 New Holland L175 (A47477)
2008 New Holland...
