2014 GM Sierra/Silverado
   / 2014 GM Sierra/Silverado #21
We already had lots of gas engines built to run like diesels in the 70's- 80's. They were awful.
When GM started stuffing their diesels in Fords & GM mediums way back, it improved medium duty reliability immediately.
I was fueling up today and a Ford pulled up with a 370 gasser with the typical exhaust manifold leak they all eventually got. I thought I was back in 1984 driving my F-700 with a whopping 175HP gas motor.
You're not in 1984...My late 90's V10 is about to sound like a machine gun...The manifold studs are rotting off . Just waiting for it to start. And it will.
There will probably be a set of Banks headers in my future (sadly at $1500 per set)..My '70 Chevelle still has the original manifolds and bolts..Never blew a plug on it either...At least Banks was smart enough to make everything out of stainless given the pathetic size of the stud/nut assembly that Ford dreamed up.
One of the box trucks I used to drive was an '87 F-600 with the 370-4V, it spent almost as much time in the shop as it did out of it. What I remember most of all about it was the 5.5 mpg it delivered....after less than a year, the fuel credit card was cracked in half because it got run thru the card machines so frequently.
   / 2014 GM Sierra/Silverado #23
I wish this were true. I like the 6.2 L a lot but there is a big difference between 417 pound feet and 765 at much lower rpm. This point made, I do see where future higher torque numbers from gas engines with multigeared tranmissions could close the gap between gasoline and diesel power in work or pulling applications. I would not at all be surprised if gm could get an updated 6.2 to get 23-24 mpg unloaded on the highway if geared appropriately and in a more aerodynamic package. Even if trucks there is a good bit of room to improve the drag coefficient which would result in much better highway economy, regardless of engine.
John M
What does it matter? The torque on the drive wheels is the same.
   / 2014 GM Sierra/Silverado #24
How can you compare a carburated gasser of the 60's,70's and 80's and decide to purchase a diesel today because of the difference?
Don't know where you have been the past three decades but Rip Van Winkle but things have changed.
Have you looked under the hood of a 2007 and later diesel and a gasser of the same era? In particular the direct injection gasser?
The diesel is the complex, costly to maintain engine. The diesel costs much more to purchase. Every scheduled service is more expensive. The fuel costs more per gallon. The cost of diesel service after warrenty expires will make you wish you had bought the gasser.
Only thing I see diesels do around here is have a stack or two up through the bed with no muffler and a programmer . Lots of smoke, noise and look at my big p*nis.
   / 2014 GM Sierra/Silverado #25
I hear ya. After the 370/429's came the Ford 460's. Still blew manifold gaskets. You could always here a Ford truck gasser coming from a 1/2 mile away.....
tap-tap-tap-TAP-TAP-TAP TAP
Oh man, those were the days. Ford 370/429's and 460's with a whopping 175-225 HP and about 390 torque. I remember them well. You needed a good set of 4 way flashers and a couple quarts of motor oil to get through the day.
Gas engines have come so far since then.
   / 2014 GM Sierra/Silverado #26
And who could forget the small behind those lumbering elephants? A mixture of unburnt fuel and throw-up. :)
I recently towed my Bobcat for a good long run (3 hrs) and up through a steep mountain pass. While my truck performed admirably (2012 2500HD), the 6.0L gas engine was screaming at 4-5K rpms uphill. I was more than able to keep up with traffic and move at the speed limits. However, I can see the attraction to the diesel when you have a load hitched up. It certainly will move along fwith less effort.
But if I had the diesel, I feel like I would have had the ablility to accidentally throw the truck and trailer into some tight turns a bit to fast. As it was, I caught myself going to fast for the conditions and having to brake a little harder than I felt comfortable on occasion. Even with the very capable new chassis in all three truck brands, I feel that the diesels are just to much engine for the truck type. Too easy to get a huge load rolling to dangerous speeds.
   / 2014 GM Sierra/Silverado #27
My understanding is that the 1/2 ton trucks will be a full redesign and the 3/4 ton are likely to follow by about 6-8 months and are likely mainly external styling and much-needed interior upgrades. As noted, for 2011 model year, the 2500/3500 series trucks were essentially redesigned aside from styling, as the budget at that time did not allow that apparently. There have been some spy shots of the heavily-disguised 1500 level truck with interior shots that show a complete interior redesign. I am not in the automotive industry, but this is what I have heard. Those with more specific information are welcomed to contradict this.
John M
This is correct. 1500's will be ALL new. HD's will be MOSTLY new, only SOME sections of the frame carry over (the most recent frames are pretty good!) The 1500 Silverado will be unveiled Dec 13th, the 1500 Silverado and 1500 Sierra will both be at the Detroit Auto Show in January 2013. I'm not sure when the HD's will debut (probably fall of 2013).
   / 2014 GM Sierra/Silverado #28
I am not sure I know what you mean here. Are you trying to say a diesel dura max with 765 pound feet of torque at less than 2000 rpm and 600 or more throughout its operational band from 1000-2600 rpm has applies the same torque to the drive wheels as a gas engine which has a max torque of just over 400 and similar rpm torque of 300 or less pound feet? With regard to the multigeared transmissions, my understanding is that this should allow whatever engine to spend the brunt of its time in the appropriate rpm for maxium efficiency and then progress out of less efficient ranges more quickly. Especially in a gasoline engine which has lower thermodynamic efficiency than a diesel this should certainly help fuel efficiency. I am not so sure I agree fully with the comment about diesel being much more expensive to maintain at least in my personal experience. For regular maintenance my gmc takes 10 quarts of oil, where my prior gasser took 6.5. The filter cost is roughly the same, so no real loss there. I do put in a wix HE fuel filter about every 15,000 miles but it can sometimes go longer. This costs me about $35.00 and I do it myself. My truck gets 20 mpg in unloaded highway driving, and about 13-14 pulling a trailer of up to #10000. My gasser got 17 unloaded and 7 mpg pulling 2000# less and did not pull it as well nor was it rated for as high a gross weight. True, there is some additional cost associated with owning a diesel, such as the Allison transmission fluid and filter change in mine and the cost of fuel being higher, and I would not argue that owning a diesel is cheaper than gas, but the cost difference is pretty small day to day and with appropriate maintainence the diesel will stand up to hard work better and last much longer due to its heavier componetry. My neighbor has a silverado duramax with 300,000 or so miles on it. Aside from regular maintainence he has never touched it with a wrench and pulls heavy gooseneck cattle trailers back and forth to the east coast of NC to and from sales. I can think of no gasoline pickup with similar miles that I would try that without a firm backup plan and his truck runs essentially like new with no signs of slowing down.
John M
   / 2014 GM Sierra/Silverado #29
I should also mention that my duramax is 100% stock, no chip, no stacks, no noise. It does not need all that as it runs quite well without those additions. I intend to keep it that way. Every blue moon, I wonder if I could get by again with a gas engine, but in a truck that weighs #7200 and is comfortable, very powerful, stone reliable, easy to drive and consistently gets 2-3 mpg better than my wife's Acura MDX (2011 model) just driving around a cannot see trading it, even if I used it as a daily driver, which I don't.
John M
   / 2014 GM Sierra/Silverado #30
John M
Keep it. They were probably the best running diesel pickups ever built. I've had GM & Ford diesels from 1991-present and in the genre you own, there's just no comparison.
Don't want to flame Dodge. may be very good, but haven't owned a Dodge diesel since mid 90's.
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2009 INTERNATIONAL 9200I TANDEM AXLE WRECKER (A58018)
2009 INTERNATIONAL...
72in Forklift Safety Basket (A56857)
72in Forklift...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56435)
2023 Top Air ATV...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
