2014 Mahindra Max 28 XL HST
   / 2014 Mahindra Max 28 XL HST #1
patwright0331
Waxahachie, Texas
Mahindra Max 28XL
I have a 2014 Mahindra Max 28XL HST it was turning itself off like you turn the ignition off all the electrical is dead but the hazards work. The battery is good the connections are clean. Sometimes I could start it back up. Here's the weirdest thing when it was running if you switch the lights on the tractor shuts off if you turn the lights back off the tractor can be started again. That was how it worked for awhile now the tractor is just dead it won't start at all. NO clicking nothing just dead. I changed out the ignition switch didn't help $120 bucks out the window I have spent two days climbing all over that tractor looking for a loose wire. I had the battery checked it is A-OK. When it was starting I would turned the key to the RUN position not in the START position just in the run position, it would make a series of clicks like something was trying to engage but then nothing would happen and the lights on the dash would be flickering at the same time it was clicking.
Anyone have any ideas?
Thanks in advance for any help :confused2:
2015 CASE 580N (A47477)
2015 CASE 580N...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
2007 International 7600 Tri-Axle Dump Truck (A55788)
2007 International...
2019 Doosan LCV6W Towable LED Light Tower (A55851)
2019 Doosan LCV6W...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
New Holland 3930 (A53314)
New Holland 3930...
