2020 is a diesel. It wouldn't be much of a chore to hit the JD store. New radiator looks to be copper, certainly not aluminum or plastic. I put water in it because when the hydraulic coupling got between the fan blade and the radiator, all the fluid came out. I didn't have anything decent to put into it after the repair. I'll forget the prestone cleaner although the manual says to clean it every year, but doesn't say what to use, much less what antifreeze to use. Yeah, I change the antifreeze in my cars every 5 years, if I keep them that long. No filter in this 2020 cooling system. At least it's not leaking now like it used to. I'll ask at the dealer if they think I should use a cleaner before I put the new A/F in it. It'll probably be the last time I use antifreeze in this tractor at my age and it's too.
I've never had any cooling issues with this 2020, actually it's mostly hard to get up to temp and I'm pretty sure I put a 175 thermo in it last time I messed with it. That's what the gauge is running at now after a good warm up and in this 90° heat. In the winter sometimes I would block the radiator to get the temps up while plowing snow.
