2023 Kubota L6060HST Compact Utility Tractor (A56436)
Item Details
Auction ID
56436
Make
Kubota
Type
Year
2023
Auction House
Fastline Auction, LLC
Model
6060
Florida
Description: The Kubota L6060 is a 62 horsepower, four-wheel drive compact tractor with 53 PTO horsepower. It features a turbocharged four-cylinder diesel engine and a hydrostatic transmission with Stall Guard PLUS. Key specs include a 13.5-gallon fuel capacity, a Category 1 & 2 three-point hitch with a 2,976 lb lift capacity (at 24 inches), and a 4,023.5 lb operating weight. Engine and performance PTO: 540 rpm rear PTO standard, with a mid-PTO option Engine: 62 gross HP, 53 PTO HP, four-cylinder turbocharged diesel engine Transmission: HST Plus (Hydrostatic) with three ranges and a 6-speed adjustment via the H-DS handle Drive: 4WD Hydraulics and hitch Hydraulic flow: 9.4 gpm Three-point hitch: Category 1 & 2, with a lift capacity of 2,976 lbs at 24 inches Loader lift capacity: Over 2,000 lbs at the pivot point to full height Dimensions and weight Operating weight: 4,023.5 lbs Fuel capacity: 13.5 gallons Turning radius: 9.2 ft Tire size (front): 9.5-16 Tire size (rear): 14.9-26 Year: 2023 Make: Kubota Model: L6060HST Serial No.: KBUL5FHRCN8L53486 Hours: 2 Meter Reads: 2 Transmission: Hydrostatic Enclosed Cab: No Stock No.: E79691 FASTLINE SALES REPRESENTATIVE(s) Trevor White trevor.white@fastline.com 251-215-3393 Item Location - Address: Provided by Seller Item Location - City: Bradenton Item Location - State/Province: Florida Item Location - Postal/Zip Code: 34212 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 16500.00 USD
Auction Finishes: December 16, 2025 at 05:34 PM
Click Here To Bid Now!
Happy Bidding!
Rooster Weathervane (A55853)
Rooster...
2018 Grove 700E 60T Crane (A60460)
2018 Grove 700E...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
20800 (A56859)
20800 (A56859)
