2023 Kubota L6060HST Compact Utility Tractor (A56438)
Item Details
Auction ID
56438
Make
Kubota
Type
Year
2023
Auction House
Fastline Auction, LLC
Model
6060
Florida
Description: The Kubota L6060 is a 62 horsepower, four-wheel drive compact tractor with 53 PTO horsepower. It features a turbocharged four-cylinder diesel engine and a hydrostatic transmission with Stall Guard PLUS. Key specs include a 13.5-gallon fuel capacity, a Category 1 & 2 three-point hitch with a 2,976 lb lift capacity (at 24 inches), and a 4,023.5 lb operating weight. Engine and performance PTO: 540 rpm rear PTO standard, with a mid-PTO option Engine: 62 gross HP, 53 PTO HP, four-cylinder turbocharged diesel engine Transmission: HST Plus (Hydrostatic) with three ranges and a 6-speed adjustment via the H-DS handle Drive: 4WD Hydraulics and hitch Hydraulic flow: 9.4 gpm Three-point hitch: Category 1 & 2, with a lift capacity of 2,976 lbs at 24 inches Loader lift capacity: Over 2,000 lbs at the pivot point to full height Dimensions and weight Operating weight: 4,023.5 lbs Fuel capacity: 13.5 gallons Turning radius: 9.2 ft Tire size (front): 9.5-16 Tire size (rear): 14.9-26 Year: 2023 Make: Kubota Model: L6060HST Serial No.: KBUL5FHRVN8L53490 Hours: 2 Meter Reads: 2 Transmission: Hydrostatic Enclosed Cab: No Stock No.: E79778 FASTLINE SALES REPRESENTATIVE(s) Trevor White trevor.white@fastline.com 251-215-3393 Item Location - Address: Provided by Seller Item Location - City: Bradenton Item Location - State/Province: Florida Item Location - Postal/Zip Code: 34212 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 16500.00 USD
Auction Finishes: December 30, 2025 at 06:26 PM
Click Here To Bid Now!
Happy Bidding!
Towable Diesel Generator (A59228)
Towable Diesel...
White 5100 / 6900 Planter (A59814)
White 5100 / 6900...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2015 Freightliner Coronado (A60460)
2015 Freightliner...
