2040 steering problem
   / 2040 steering problem #11
Sorry I don't have access to a JD utility tractor tech manual but valves don't require re-shimming just to R&R orings
   / 2040 steering problem #12
When you have the steering shaft with valves installed on shaft, turn the valve bodies so you can see the plungers in the holes on the side. Wrap the lower end of shaft in a heavy rag and put it in a vise in the horizontal position. grab upper valve body in one hand and the lower valve body in the other. push both valve bodies together and slide them slowly back and forth wile looking at the plungers. You need to be able to feel a "neutral" where you can move the valve bodies a small amount without the plungers moving. If you can't, you need to add shims until a neutral is obtained. If the neutral is too big(more than about .010") you can remove shims to get it to .010" or less. It is better to have too much neutral than not enough. I hope that makes sense. It is difficult to explain without demonstrating it.
   / 2040 steering problem #13
Shimming needs spesial tool , but thats the princepal it works on , remembet that the valvebody with the extra hole comes at the bottom for the return oil !
   / 2040 steering problem #14
How can the valve bodies(parts key 23) be different if they share the same part number?????
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
2012 VANGUARD 53FT DRY VAN TRAILER (A53426)
2012 VANGUARD 53FT...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2019 TY-CROP MANUFACTURING LTD DRY BULK TRANSPORT TRAILER (A53843)
2019 TY-CROP...
Electric Forklift Pallet (A50322)
Electric Forklift...
