20hp CUT with 60" BB?
   / 20hp CUT with 60" BB? #1
smokedtires
Bronze Member
Lysander NY
20hp CUT with 60\" BB?
Hi all, I ordered a 48" King Kutter CAT1 BB from TSC about a month ago and they still don't have any details of when it'll be in. I'm wondering if I could just buy the 60" they have there or if it'll be too much for my tractor? It does have R4 tires on it if that helps.
Has anyone tried a 60" with a 20HP diesel CUT, or should I just find a 48"?
I would be willing to buy from someone else locally if I had an idea how to locate a box blade dealer.
TIA
   / 20hp CUT with 60" BB? #2
Re: 20hp CUT with 60\" BB?
Depends alot on your soil. My 45hp NH has a 6' BB and when it gets into the soil ( alot of clay and shale rock deeper in the ground ) it is all it wants to handle. The tip and tilt is great for getting the most out of each pass. I am sure my 4110 would be at max with a 4'. Not enough weight to do a good job with a larger cut. If you have sand and loose black dirt I can't see a problem going larger. Let us know how it works out. ( there should be alot of manufacturers of 3 point equipment out there)
Thanks Joe. I also posted this in the attachment section, and it looks like the consensus is that I should stick to a 48". Now to go and bug them at TSC !
   / 20hp CUT with 60" BB? #4
I have a John Deere 4100HST (20hp) with a KK 60" box blade, FEL, etc. It came that way when I bought it. I would have thought 60" is too much, but it handled 250 yards of sand and clay fill just fine. At the time, I had turf tires, and it had decent traction, but now I have R-4's and it's better. In the end, I'm glade it's 60".
2014 D&P WELDING 16FT PRESSURE WASH TRAILER (A52472)
2014 D&P WELDING...
Super Material Lift MH1000 (A52748)
Super Material...
2021 Liebherr L556 (A52748)
2021 Liebherr L556...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2015 MACK CXU613 (A52472)
2015 MACK CXU613...
