$21,500 buys which tractors
   / $21,500 buys which tractors #11
In that price range I just bought a brand new JD990 MFWD; R4 Tires; Rear wheel weights; 300CX loader; Grill Guard; LX5 Bush hog w/clutch & safety chains; HD Bucket upgrade w/Toothbar; rear work light too
   / $21,500 buys which tractors #12
My local dealer had a Zetor 6341 open station MFWD with 18.4 34 rears for 19,999 new. Did not see it there last week when I went by.
Zetor loaders are sturdy, my 84" bucket was $300 as I recall did not need it as I primarily use a 96" snow bucket, forks, and a fancy rock bucket grapple. Still haven't used that dirt bucket.
I bought in Jan '04 and the factory was running discounts on loaders ordered with tractors.
If you have visitors adding a jump seat is a good safety feature
   / $21,500 buys which tractors #13
What price range? what did you pay for it?,,,just told you all what northerns catalog says,,,to the penny,,,what was it,,15,500 for 40 hp and loader?,,,brushog,,add 600 or so for 6 ft kingkutter,,add another 500 -600 for heavy duty box blade,,add another 500 or so for heavy duty 6 ft blade,[which by the way my 254 uses],,so better step up to 7 ft,,another 100,,,,so thats about,,what 18,000,,for 40 hp 4x4 tractor,,with fel,,box blade,scraping blade,and 6 ft hog???heck,,he's got mony left over to buy a tiller,and 48 inch plasma tv,,,thingy
   / $21,500 buys which tractors #14
Try looking at a montana My Montana tractor is 6 months old but there has been a price increase since I bought mine and mine has a cab so I am not sure exactly what the current price is for a non cab model. I have a 4940C.
this has 4 wheel drive 16 gears, front end loader, two remote hydraulic connections and controls, the engine is made by mitsubishi. When I bought mine you could get a 4940 (which is a 49 horse) non cab version for less than the money you said you wanted to invest. I would not be suprised if the new prices were close to that amount now. You can go to the montana forum on TBN and post this question. There are a couple of montana dealers there that might be able to help you if you are interested
   / $21,500 buys which tractors #15
Doc_Bob said:
I bought a used 2003 New Holland TN70A with 8x8 Power shuttle tranny, QA bucket, QA pallet forks, 6 foot Bush hog, 3ph rear blade with 168 hrs on the clock for 21,600.
Bob
Sweet, very sweet! Wish I would've met the seller before you!:D
   / $21,500 buys which tractors #16
The units you listed are good ones. If I was in your shoes I would give Manhindra a good long hard look. They list a 5500 4WD for $20,900. With a 20% discount that gets you into the $17K range. Add the loader and you are very close to your $21,500 budget. This is a much heavier tractor than the others listed. If I was farming and was gonna lift round bales this is a tractor I would give strong consideration to.
   / $21,500 buys which tractors #17
CWP37 said:
I need to move large round bales on the FEL, shred pastures 3-4x per year (6 footer) and box blade my driveway 1x year.
The '00 series Mahindra tractors are probably overkill for what you need, but the they are the biggest HP bang for the buck out there. With 4wd/FEL, you get synchro shuttle shift and heaviest in class. My $.02 worth. Good luck with your search. BobG in VA
   / $21,500 buys which tractors #18
I was very lucky in finding it. Today I have 127 hours on it since I bought it. Temp around 50 degrees, great day. 6 hours in the seat.
Bob
   / $21,500 buys which tractors #19
I got my L4400, 4wd, loader and a set of rear remotes for about $19,000. So for $21,500 you could probably add a nice medium duty 6' mower and maybe a box blade too.
I doubt you could get the MX5000 for that price with 4wd and loader. If you can...then go for it.
   / $21,500 buys which tractors #20
I imagine the FEL would be the "rate-limiting factor". The MX5000 does give the most bang for the buck though (as far as Kubota goes).
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2008 Genie GTH-844 Telehandler (A54865)
2008 Genie GTH-844...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2018 FREIGHTLINER...
