2120 purchase
   / 2120 purchase #1
jimmysisson
W.Mass
1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
Hello. Are there any special things to look for in a 1200 hour 1993 2120, 12/12 shuttle, mfwd, loader/qa bucket? It's a one-owner private-use job with soft cab + some implements for $13,500. Uses will be snow plowing, light logging, brush hogging, grading woods roads, etc. It would be my first 4wd tractor, though I got my first Farmall A 33 years ago. I'd appreciate any comments. Thanks, Jim
   / 2120 purchase #2
If you do a search in the various forums there's some info there. I think the most common ailment has something to do w/ the power shuttle which I believe it's an electroincs problem. I know at least one other member her owns a 2120 so let's see if he checks in.
   / 2120 purchase #3
The 20 series were and still are one of Ford/NH's best compact tractors. They are a simple, reliable tractor. There is not very many complaints about them that I know of and if there is it is usually an isolated problem. Rick B will be able to tell you if there is any type of common problem with the 2120. I have a 1920, my neighbor and old boss has a 1920 he uses on his fruit farm and another of my friends has a 2120. All three are FWA and two have loaders and the only problem I have with mine is a faulty safety switch that wouldn't let the tractor start from the key.
   / 2120 purchase #4
I've got a 1996 2120, purchased 2 years ago with 600 hours. It's at 1350 now, and I've used it hard, logging, land clearing, and now I've stuck a 758 bachhoe on it. The only issue I know of is on the earlier ones the transmission bolts would loosen. I check mine once in a while, nothing loose yet. I just bought a stone bucket, I wish mine was the q/a. I guess. Probably adds some weight and the bucket is around 600 lbs. now. I'm getting better at switching buckets, tho.
   / 2120 purchase #5
I have to agree on the comment about the 20 series tractor. i had a 1920.. love dthat tractor.. probably the best compact tractor I've ever owned
I'd treat it like any other new to me/use dpurchase. look for oil in the water.. water in the oil.. check fluid inthe sumps.. dirive in all ranfges / rpm.. let it get warm.. check hyds and for leaks.. check shifting.. etc. And cold starting.
Soundguy
   / 2120 purchase #6
I had a circa 1988 Ford 1920 also(one size down from the 2120) and it was a great tractor. In some ways, I liked it better than the Kubota L4330 I replaced it with. The bad thing was non-syncro transmission but I think your shuttle version addresses that. The only problem was a power steering pump in 1100 hrs.
John
   / 2120 purchase #7
I have had the luxury of using both trannys in the 1920's. The Shuttle is much nicer but I did not have any trouble with the base tranny. It is like the older tractors where you have to be completely stopped before you change gears. Not a problem if you are use to older tractors but I can imagine it would suck if you are use to a syncro tranny.
   / 2120 purchase
Hi guys. Thanks for the info. I bought this right away unit after inspecting it. It's as good as it can be at 1200 hours: oil changes every 100 hrs, no repairs at all in its lifetime, Sims cab w/soft sides which seemed like a good cross between protection and access. Good tin and paint and tires. Also has the q/a bucket, HD forks, and a Fisher pickup snowplow with p/a set up for the q/a with the angle run from the rear remote. He threw in a decent Norse light logging winch and we shook on $14K. I'm happy and can't wait to put it to work. Now, we'll see if 4 wd is all it's cracked up to be (I know it is). The former owner is going to get a rubber-track skidsteer to move materials and plow his drive, he's retirement age. Appreciate all the comments, Jim
2010 CATERPILLAR 140M MOTOR GRADER (A51246)
2010 CATERPILLAR...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53472)
2024 BCL...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
