2155 Front Drive Shaft and LH / RH Lift LInks
   / 2155 Front Drive Shaft and LH / RH Lift LInks
Thank you both. I will follow up on the fix when I get there.
Thank you Zebra5. Sorry for the late reply. Had an injury that has sidelined me. Starting this project again. Snow on the ground so 4x4 would be good to get through the woods.
I'll follow up on what I learn and find.
Update. I found one place that had the appropriate DIN 6 hold flange for the front axle. Turns out JD used a standard metric flange of 100mm OD, Pilot 57mm, bolt circle 84mm, number / size of holes 6, 8mm. I only found one US driveline shop to supply this flange and the appropriate 1 3/8" 21 spline, and they are building the drive shaft now. I spoke with my local automotive trunk driveline, transmission shop and they recommend for AG stuff to call these guys. Chuck was super helpful.
DRIVE LINE SERVICE OF FRESNO.
I'll update once installed. I will fabricate a appropriate drive shaft protector that will protect the shaft going through the woods.
New Holland B95 Backhoe (A50490)
New Holland B95...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
John Deere 2155 Tractor (A51573)
John Deere 2155...
