21HP CUT and a blower... am I dreaming?
   / 21HP CUT and a blower... am I dreaming? #11
The thing is, then I'll need chains, and eventually a cab, and then I might as well add some heat and a radio, and then....
...... heated driveway... :)
   / 21HP CUT and a blower... am I dreaming? #12
My tractor is 23 hp (18 at the PTO) and I have the 51" Kubota snowblower. I use it on a 1/4 mile gravel driveway and I love it for the deep snowfalls.
I also use a plow for lesser amounts.
   / 21HP CUT and a blower... am I dreaming? #13
Thanks all for the excellent feedback. Looks like the 5' sold on CL so I'll be on the lookout. Based on some mfr websites, 48"-54" is right in the 17hp wheelhouse, so I'll probably be in that range unless another 5' comes up for a bargain.
You might as well get it over with, go trade for a 30 or 40hp, cab(heat A/C, sat radio), FEL, Hydro, front mounted blower....0% interest:D
   / 21HP CUT and a blower... am I dreaming? #14
Hedouble hockey sticks dont stop there!!!
when I started dream ordering my Kubota 2360 I had:
1. Turbocharger
2. Brotek skid belly protection
3. Fully sound proofed cab from Canada
4. Air conditioning
5. Reverse air flow/positive in cab ventilation
6. Moveable lap top desk
7. Front and rear HID work light bars
8. high output alternator
9. 110/220 volt mounted generator
10. Satellite radio
11. Nokian rear snow tires
12. loaded rears with WWF
13. V lug snow and ice chains
14. front end loader
15. rear mounted 72 inch Pronovost 2 stage snow caster
14. AM FM radio with CD player
15. Short wave radio
16. weather radio
17. air cusioned swivel seat
18. 3 hydraulic outlet pairs
It was fun reminiscing about my dream mule
   / 21HP CUT and a blower... am I dreaming? #15
I run a 10' blower on a Deere using 15 HP per foot at 1000 pto...15 HP per foot seems to keep things moving....When one has the time and a creeper gear to cut small passes, you can run a blower that should be sized to wheel width......A cab is a must for all day snow blowing
   / 21HP CUT and a blower... am I dreaming? #16
If you can lift it, and you have enough traction to push it, and the driveshaft lines up fairly well, AND if you can vary your groundspeed for the volume of snow... there is no such thing as too big of a blower. Well, maybe if you can see around it, too. You just have to make sure you don't try to stuff more snow into the thing than it can throw out at RPM. That's why God invented HST's.... :)
How would you know anything about snow? You guys don't get any do you?? !!! The chains work great by the way, a little cutting and welding and all's well. Thanks again Jerry. I hope we actually get a good winter this year, I am tired of all the people who moved up in the last few years complaining about how bad it is. Bring back 1978-79!! CJ
   / 21HP CUT and a blower... am I dreaming? #17
:) We got off pretty good a year ago, but last winter we received over our average 140". I live just S/E of Boyne Mtn.. well you know where, you picked up the chains.. [ a big ski hill, not a big moutain to you moutain folks.. ]. We usually get one big snow at the first of the season, a system snow, then get daily lake effect the rest of the winter. Then another system snow in the spring. Usually get enough snow that the ground is insulated out in the woods and never get any frost to speak of. Last ten years, we still get the lake effect, but we are getting more and more of the system snows that usually hit downstate. The big thick heavy stuff.... Don't like it... But my blower is all painted up, greased, and ready to go... :)
   / 21HP CUT and a blower... am I dreaming? #18
I have a bx24 which I think is similar and I was having someone plow the driveway. Last year I got a used 5' Puma rear blower. In general it worked well and handled one snow fall that reached to the top of the blower.
I added a winch and actuator arm to be able to rotate and direct the outlet which made things easier. Also found I needed chains both front and back. The problem comes when you get a good size snow fall overnight and in the morning it is raining with a hard freeze forecast for later in the day. It can be a mess, especially down by the road where the town plows and there is too much water in the snow for the blower to lift and throw through the chute. I needed the front bucket or a call to the plow truck to help out. Don't need no cab, its lovely out there when its pouring down and the wind is howling throwing it back at you wearing glasses and doing neck exercises dreaming of the truck you used to have.
   / 21HP CUT and a blower... am I dreaming? #19
I bought my 60" Lucknow from a retired CBC executive who used it for many years on a 18 hp Ford Hydro 2WD. He said it worked fine on the little tractor. I have used it on a 37 hp MF 35 and a 35 hp TAFE (with loader and cab) but this year I plan to try it on my 21 hp Kubota B7510 HSD.
I found a very nice used Agro Trend on eBay, just gotta make the drive to get it. Will post up some pics when I do. $700 looks brand new and 48". Now I have to sell the truck to justify it...
New/Unused 75in Skid Steer Soil Conditioner (A51573)
New/Unused 75in...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
18ft Refrigerated Box for Cab and Chassis Truck (A51573)
18ft Refrigerated...
2023 John Deere 6120E MFWD Tractor (A53342)
2023 John Deere...
2016 Komatsu D61PX-24 Crawler Dozer (A51573)
2016 Komatsu...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
