joecdeere
- Joined
- Apr 13, 2002
- Messages
- 1,710
- Location
- Cumming,Georgia
- Tractor
- 1948 Allis UC Hi-Crop Cane 1941 Allis WC 1948 Allis G with loader, 1948 Allis G with dual disc 1948 Allis G 1948 Allis G 1949 Allis G 1954 Allis G 1959 Ferguson TO-35 1972 MF 135 1979 Power King 2418 1989 Ford 345C TLB
Solution Number: 59293
Solution Summary: Oil Leak from Center Link Support Plate
Publication Date: May 9 2003
**Paper copies of solutions may not be the most current solutions**
Complaint or Symptom: Oil leaking from Center Link Support Plate. This plate is where the Center Link attaches to the Rockshaft.
Problem or Situation: There could be a few issues that could be causing the leak.
1. Fastener torque (hardware could be loose)
2. Seal (may be cut or deformed)
3. Plate (plate could be warped or bent)
Solution:
Check fasteners to ensure that they are torqued correctly. If fasteners are torqued to spec, remove the plate and inspect seal. If seal is cut, remove seal and install new liquid gasket.
If there is not an issue with the torque or the seal, order a new cover plate and install on the machine.
Parts:
LVA801316
Solution:
Parts:
LVA801316
