2305 50hr service - Any suggestions
   / 2305 50hr service - Any suggestions #1
JCCinOhio
SW Ohio
JD 2305
My 2010 2305 is ready for it's 50hr service which I plan to do myself. I noticed on another thread that the oil filter can be a pain and a snap-on channel lock type wrench works great. Are there any other recommendations for making the 50hr service easier? I think while it's in warranty I'm going to use only JD parts and fluids.
50hr: Change engine oil/filter, change transmission oil/filter, clean suction screen.
On a side note.. I did the first oil change on my Toyota Matrix (got it for the gas mileage as I drive a lot) and found out I needed a special 64mm socket to remove the oil filter housing (has a paper filter). After looking around I settled on the Assenmacher metal socket for Toyota that I found online from Advance Auto.. part number ASSTOY640.. :laughing:
   / 2305 50hr service - Any suggestions #2
My suggestion is to stop at an Auto Supply House, O'Riley, Advance, AutoZone and obtain a needle injection tip with at least a 4-5 inch extension for your grease gun. The drive shaft from the engine to the transmisson has a grease fitting CONCEALED in both of the U-Joints. You will need the needle injection system to get grease into the grease zerks. Several have posted on here about the u-joint breaking and damaging the tractor. (This is when they found out about the grease zerk and were warning others) Getting grease into the u-joints will be the hardest and most time comsuming part of the service.
I would not pass on greasing the u-joints.
I found the information the Tractorbynet poster provided. You need a alemite B6783 5" inch needle nose adapter. Look to pay 20-25 dollars for this tool.
   / 2305 50hr service - Any suggestions #3
I recently did mine. It's pretty simple. The suction screen can be a bit tricky to wiggle in and out of the trans. The o-rings that provide the seal are stubborn to get moving and there's not a ton of room for both hands AND to see what you're doing.
FYI - you can find that style filter wrench at Tractor Supply also.
I feel your pain about the Toyota filter. I have a 2010 Tundra that requires removal of a skid plate, and that special tool. Fun.
Gator- Thanks for the tips.. I'll have to get one of the zerk adapters. I see what you mean about them being hidden. When I first looked I thought "there's no zerk here..."
Ironhand - See what you mean about the suction screen. Getting the hose off/on was tricky. Too tight to push it up/down or over. Ended up twisting the suction screen cover ~45 degrees till the hose twisted off.. the did the opposite to get the hose on. I like the F4 pic.. Used to love to hear those things rumble..
Oh.. and just for grins I asked the dealer what they would charge for the 50hr service.. First answer was 4hrs at $70 +parts... I said WHAT? Then he said he guessed they could do it in 2hrs +parts.. I think it took me about 2 hours and it was my first time...
   / 2305 50hr service - Any suggestions #6
Be sure to tighten all fasteners as well.I found alot of loose ones when I did the 50 hr on my 748.I took alot of them out and gave them a coat of blue locktight.
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
16FT flat bed trailer (A53424)
16FT flat bed...
2005 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A54313)
2005 FREIGHTLINER...
2008 New Holland B110 MFWD Loader Backhoe (A55218)
2008 New Holland...
