2305 and mower hight adj. knob
   / 2305 and mower hight adj. knob #1
fdmars
Central CT
John Deere 2305 w/ Femco folding ROPS & Power Beyond Kit
Am trying to install the mower on the 2305, I cannot get the knob to move, stuck in the lock position, is there something I am missing? Thanks Fred
   / 2305 and mower hight adj. knob #2
you have to have lift arms or ind lift raised to highest setting before you can turn the knob.
will try again, that is the same as the 3 pt hitch lever, correct, I did raise it all the way. but the knob would not turn.
   / 2305 and mower hight adj. knob #4
Prerequisites to posting a question like this (or any questions, really):
1- Know what equipment configuration you have, in this case mechanical lift or independent.
2- Read your manuals
:mur:
   / 2305 and mower hight adj. knob #5
assuming the mower is NOT on the tractor yet, the 3 point lift all the way up, you are trying to drop the mower arms, you have the spacer installed between the rear lift arms; answer is there is something wrong.
assuming the mower IS mounted and you have the spacer bar installed in the rear lift, you raised rear lift fully; knob is stuck, I had this issue when my 2210 was new, had to shake the deck by physically to loosen the knob.
good luck!
   / 2305 and mower hight adj. knob #6
Don't pay any mind to negative diatribe. Many times when you "read the manual" you will not comprehend what they say. Sometimes it is easier to see the written words of regular guys, not engineers. Post what you want and when you want.:laughing:
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
2015 Chevrolet Silverado 1500 Pickup Truck (A55788)
2015 Chevrolet...
2004 Ford F-250 (A53422)
2004 Ford F-250...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A55218)
2008 Ford F-250...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A55787)
2025 GIYI GY-ZWB...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
