2305 fan in radiator
   / 2305 fan in radiator #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
I took delivery of my new 2305 less than a month ago and tested the tiller for a few minutes then parked it in the garage. We finally got some snow this week to test the snow blower and I hit a construction joint in the driveway. I was going pretty slow because I was getting the feel of how well everything works. Today I found pieces of plastic in the driveway and discovered the fan had hit the radiator. I told the dealer I had read of this defect here at TBN and he was going to check into it. I hope Deere comes up with a fix soon because I feel this is going to happen again. Hope I am wrong.
   / 2305 fan in radiator #2
I agree. There is very little clearance and adjusting the mounts doesn't help. There is a lot of movement in the radiator.. I have one that damaged the radiator. It was replaced quickly by my dealer. I have not heard anything about an update or fix for this problem.
   / 2305 fan in radiator #3
read and check these things-
Solution Number: 69262
Solution Summary: SIB 05-11-35-05 Engine Fan to Coolant Radiator Interference on 2305 Advantage Series Compact Utility Tractors
Publication Date: Sep 21 2005
**Paper copies of solutions may not be the most current solutions**
Complaint or Symptom:
Problem or Situation:
Solution:
Clearance Inspections and Potential Adjustments
2305 Advantage Series Compact Utility Tractors with an Invoice Date prior to 21 September 2005
____________________________________
There is the possibility to have engine fan to coolant radiator interference which will result in radiator damage. Follow the checks and procedures below to insure proper clearance between the engine fan and radiator.
1. Engine Fan and Radiator Clearance
The engine fan to radiator shroud clearance should be 10-15 mm, it is imperative that the proper clearance is maintained. Rotate the fan blade to the twelve o’ clock position. Measure the distance between the fan blade and the inside surface of the shroud closest to the fan blade (See PDF Link at bottom for photos). If there is less than 10 mm clearance, then the side support braces should be loosened and the radiator adjusted to get this clearance. The retaining hardware should then be tightened, starting with the upper right hand, then lower left hand, then upper left hand and then lower right hand (See PDF Link at bottom for photos).
2. Battery Position
Verify that the battery is seated fully rearward against the two stop tabs to insure that the front latch rod has free motion. If it is not, adjust the battery accordingly.
3. Hood Latch Position
Insure that the wire latch hoop on the hood is striking the retainer latch in the correct position. Verify that the lower panel assembly is installed correctly and that the locating pins are correctly in place. If lower cowl is properly installed, lower the hood toward the latch and visually note the position of the upper wire latch hoop relative to the lower retainer latch. The wire latch hoop should contact the rear of the lower retainer latch surface at least 3 - 5 mm down the surface of the latch. This will insure that the latch will consistently capture the hood’s wire hoop (See PDF Link at bottom for graphics).
With improper hood hoop latch strike, the radiator can be forced into the fan during hood closure. This occurs when the hood hoop contacts the latch on the front side (See PDF Link at bottom for photo). If the hood is open and the unit is running, closing the hood with the latch in the position shown will result in fan blade to radiator contact. The results will be a punctured radiator.
If the hood’s wire hoop contacts the latch surface at the top of the latch surface, or comes to the front of the lower retainer latch, then the wire hoop should be adjusted rearward until it comes into the proper alignment. This can be done by inserting a lever through the wire hoop and, using moderate pressure, bend the hoop rearward until the proper positioning is achieved (See PDF Link at bottom for photo).
After the hoop has been adjusted, check to insure that the hoop is striking the latch at the proper position. If adjusted correctly, shut the hood with a firm closing motion on the hood front nose area (See PDF Link at bottom for photo). Slamming the hood is not necessary.
2305
jocdeere - Thanks for the information. I will get a hard copy to my dealer.
rvtech - Have you hit any hard spots with your loader since your repairs were completed?
   / 2305 fan in radiator #5
No, I'm afraid of it now. I go very slowly everywhere.
I'm assuming my dealer did the above mentioned procedure. Maybe it's ok now. If you pull the radiator towards the fan with your hands, you will be able to make contact. Mine is still this way. There isn't any way to know how far it's going to move when you're driving.
I didn't have the loader on when the damage was done. Only the mower deck.
PALLET OF CARBURETORS & PARTS WASHER (A58374)
PALLET OF...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
SKIL SAW 10" TABLE SAW (A58374)
SKIL SAW 10" TABLE...
2020 Ford F-250 4X4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
