2305 RPMs for mowing and Fuel consumption
   / 2305 RPMs for mowing and Fuel consumption #1
wxboy
Bronze Member
Western MA
JD 2305
Just curious what RPM other 2305 owners are using for mowing with MMM and what kind of fuel consumption you are seeing when mowing?
   / 2305 RPMs for mowing and Fuel consumption #3
I've been setting the RPM's where indicated on the tach. Seems to work fine, I don't need to slow down for "heavy" tall grass. I haven't kept track of fuel consumption, but I know I'm getting twice as many mowings per tank as I did with my (gas)LX255
   / 2305 RPMs for mowing and Fuel consumption #4
   / 2305 RPMs for mowing and Fuel consumption #5
Hi:
You probably want to use the 2900 RPM indicated to get the full 2100 rpm on the front PTO. Cutting at a lower RPM will lower the cut quality since you'll reduce the tip speed of the blade.
You'll get great consumption no matter what engine speed you use so it's not worth trying to economize. I cut (Smooth terrain) full pedal on Hi in the hydro at about 9mph (Except for hills) and fuel consumption is great for the 5 acres a Mow.
   / 2305 RPMs for mowing and Fuel consumption #6
Hi:
   / 2305 RPMs for mowing and Fuel consumption #7
Slightly different but almost the same, I have a 2210 w/62C, and I run'er wide open. Been doing this for 4 years, cuts great. Tach says 3000 or so, just slightly above the "PTO" line on the tach. Doesn't use much fuel no matter what, fuel consumption way lower than my 335GT w/20HP gas.
   / 2305 RPMs for mowing and Fuel consumption #8
   / 2305 RPMs for mowing and Fuel consumption #9
Mowing 5 acres. I always run it wide open for blade speed. Uses between 2.5 and 3.5 gallons depending on load (grass height)
   / 2305 RPMs for mowing and Fuel consumption #10
Pull-Behind Reel Mower Tractor Attachment (A55851)
Pull-Behind Reel...
Unused SDJ-4000 9,000lb Two Post Auto Lift (A55851)
Unused SDJ-4000...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
Hose Reel (A55758)
Hose Reel (A55758)
