2305 starts but wont stay running
   / 2305 starts but wont stay running #1
reichebrown
JD 2305
My 2305 just quit on me. It starts but will not stay running. When I turn the key the lights that usually come on durring the "Glow plug process" dont come on. I can get the motor to turn over and run but as soon as I let the key go it stops. The fuel level gage also drops once the key is released.
I looked in the fused box and fuse C the 15 amp (engine, glow plugs and starter) fuse had blown. Any thoughts about what would cause this. Im going to try to move it to a more convenient location since its in the woods right now. I was running it for several hours before hand and was actually on my way home. I was in the process of stopping to get my chain saw when it stopped.
I will try to look for something like a bad ground first off but a blown fuse has me thinking a of a short somewhere.
   / 2305 starts but wont stay running #3
Once a diesel engine starts the only thing that will make it stop is that it is deprived of fuel. If there is fuel then it will run, if its not running then it has no fuel. So the things to check are in the fuel system, and the place to start is with the fuel pump. Is it getting power? I believe its electric on the 2305, which would comport with what you've told us. It would seem your whole electrical system shuts down when you release the key and if that's the case then its probably a bad switch (quick, relatively cheap, and easy fix).
   / 2305 starts but wont stay running #4
Same exact problem with my 2007 J.D. 2305, however I called the John Deere Headquarters in Moline, Illinois and talked to one of their V.P.'s of marketing to try and fix this two year old intermittent problem once and for all.
I told him that I've been trading with J.D. for 50 years now would rather not switch to Kubota or Mahindra at this point. He told me, "We don't want you to do that", and told me to go out and shoot a video with my point & shoot camera of exactly what is happening, ie; the tractor turns over, runs for 2 seconds and then dies...
It has been doing this intermittently for two years now, however, this time appears to have died as it has been sitting out in the driveway now for the past 4 days and will not correct itself this time. So I sent him a one minute video showing that the PTO switch is in the 'off' position, the gear shift lever is in neutral, and that the brake is locked as it should be for starting the tractor.
ONE DAY LATER, I get a call from the John Deere Augusta, Georgia plant (where the 2305 and other compact tractors are made) where one of the trouble shooting experts who viewed my video was and kindly called me.
It turns out the problem here fella's has nothing to do with the safety switches, fuel pump solenoids, the fuel pump, the fuel pump solenoid shut off switch (didn't even know they had one of those), but instead, and I am quoting here from his email to me:
"After watching the YouTube video, I would suspect that the V4 diode is failing or there is a circuit issue with the V4 diode. - Please Refer to Technical Manual "TM2289" pages 144-148 for testing and resolution of the V4 Diode, and this should remedy the problem you are having with your J.D. Model 2305. - Kindly note that the dealership can open a case with their dealer technical assistance center for additional help here should that be necessary."
Hope this helps guys... Happy Fourth, 2013...!!!
   / 2305 starts but wont stay running #5
I am having the the same problem with my 2520 and it also has been intermitten and now has failed completly. I have not been able to locate the diode in the wire hraness.
Do you have the TM 2289? I have been thinking about getting the CD copy but I am concerned that it may be as vague as the owners manual.
   / 2305 starts but wont stay running #6
If a diesel engine can be stopped by turning ign key to off then it requires more than diesel to keep it running. It also requires electricity.
   / 2305 starts but wont stay running #7
   / 2305 starts but wont stay running #8
Call the John Deere Augusta, Georgia works where your tractor is made and tell the receptionist you need to talk to someone in 'trouble-shooting'.
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2009 Toro Workman HD Utility Cart (A56857)
2009 Toro Workman...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56436)
2022 Greenworks...
