2310 HST Capacity Question
   / 2310 HST Capacity Question
tx2310 said:
You could try pulling it from the top with a hose down the fill tube it is thin oil unlike motor oil.
Doug
I tried that (~ 1/2" OD tubing) and I could not get it far enough down in to get into the oil itself. I was also concerned that if I forced it, it would get caught on something inside and with my luck I'd wind up with a major service call. I think I'd rather take my chances on getting my hands messy.
I have lots of that orange hand cleaner and paper towels on hand.... :D
Jay
   / 2310 HST Capacity Question #12
If you really don't want to remove the drain plug, you might use a suction gun and suck it out. My old 2310 would be easy, but the new 2610 has a small rubber tube that extends the hydraulic oil fill upwards and the curves in it might make feeding the tube difficult.
I was able to suction out about 2 quarts and then took it to a steep incline and when I parked it on the hill, I could see the difference.
I then backed out stopping and checking frequently so that I could get an idea about how overfull it is.
I'd guess it is over by less than a quart, so I think I'll be OK.
I'm also going to put a note into the owner's manual so that 2-3 years from now when I have to do this again, I will remember to be more careful when refilling. :rolleyes:
Jay
2022 International MV607 Terex XTPRO56 56ft. Insulated Forestry Chipper Bucket Truck (A55973)
2022 International...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
METAL STORAGE SHELF W/ 6 COMPARTMENTS (A58374)
METAL STORAGE...
207272 (A52708)
207272 (A52708)
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
