2310 suddenly loses power and engine almost stalls when mowing
   / 2310 suddenly loses power and engine almost stalls when mowing #11
Fuel filter was changed last year, about 50-60 hours ago. I understand about the pedal. I only use low range when cutting. Yes the mower is a 3 pt, 4 ft, rotary brush mower. It seems that the issue is after tractor is warmed up....for example, I expect I would be able to start it now, and mow for a while....then lose power. I do have to dis-engage the PTO otherwise, I would stall completely....and I limp back to my garage....very slowly...
Wow doesn't seem like a fuel issue if your limping back and TAC is on the green. Does the transmission sound different? Is there a louder wine? How is hydraulic oil?
OK, tried simple first. Checked fuel filter and everything looked fine so I disconnected fuel line from the fuel tank (with loose fuel cap) and diesel fuel just trickled out...so I pushed a nail into the outlet and fuel gushed out like normal....so I drained the fuel tank into a clean container straining it thru paper towels....as I tapped on the bottom of the tank. Saw significant amount of particles, that indicated possible issue. So I flushed clean diesel thru the tank, watching the out flow thru paper towel filters...did this until I saw no more residue. Then I ran the tractor for 2 hours with no additional issues.
I do not want to have to remove the tank. Is there a small flexible vacuum that can be used to clean out and residue in the bottom of a fuel tank?
Thanks for all of the feed back suggestions!
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2011 Ford F-150...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
John Deere 5075E (A53317)
John Deere 5075E...
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
