thatguy
Elite Member
I have a slight leak coming from under the seat on my 2320 - I have pretty much determined that it is coming from a nut at the top of the rear, just below the seat (see the link for pics) and it just oozes after the Hydraulic/Transmission oil heats up.. Here is the original thread with more details and pics
http://www.tractorbynet.com/forums/john-deere-owning-operating/227989-2320-how-do-i-stop.html
this leak started after i changed the hydraulic oil at 250 hrs (right at 315 hrs now).. When I drained the oil I caught it and then put that much back in, BUT it was still not showing in the sight glass (ever after running the engine and pto several times). So i added some extra oil so that it would show in the sight glass..
My question is.... Could I have overfilled it since it was showing in the sight glass before I drained it and then put that amount back in?? Andy by overfilling it it is pushing the oil out around that nut??
Honestly, I have not figured out the secret of the sight glass.. One day it shows nothing, then after using it it will show pretty much full (sight glass filled in).. Other times it will show full all the time.. Then the next time its wont show in the glass.. I have tried to be have the FEL down and the 3pt arms down when i check it to be consistant.
The over flow/vent tube right under the seat does not have any fluid coming out of it.. it just oozes from around that nut..
thoughts.. suggestions.. ideas.
Brian
Brian
