2320 loader valve
/ 2320 loader valve #1
kernal
Rochester NY
JD 2320
Does anyone know the fitting type in the 2320 loader valve? I have installed the manual 2 position valve for the mid mount mower lift, and I am un-impressed with the way it hooks up. I would prefer to replace the hardline and run directly to the 2-position valve. This would allow to have a "stock" setup on the loader connections.
/ 2320 loader valve #2
I believe its m14x1.5 banjo fitting. Best to take one out and measure it. You should be able to replace with a m14x1.5 x JIC then run hose to the selector valve. I too thought this was a dumb setup when I looked at the diagram online but I ended up not buying it.
