2400 FEL slow and weak
   / 2400 FEL slow and weak #21
generally the secondary filter only applies to the hydrostatic version of the 00 series, so if your is a manual shuttle shift you won't have the secondary filter. but if your is the hydrostatic version it will be located right next to the main line filter, just under where you rest your feet while driving your tractor.
Well if anybody is searching in the future...1 month at the dealership, $1,100 later I got the tractor back with a new hydraulic pump. Seems stupid high to me, but i didn't have much choice. They said it was pumping enough work the steering and 3point but not the FEL.
   / 2400 FEL slow and weak #23
steering is separate section on the pump from FEL & 3 point. FEL requires a little lower pressure but same pump as FEL.
Is the pump all they changed?
That's all they said they changed...said it was only the second pump they have ever had fail on a Branson.
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2008 CATERPILLAR 320D L (A52472)
2008 CATERPILLAR...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
