2400 FEL slow and weak
   / 2400 FEL slow and weak #21
generally the secondary filter only applies to the hydrostatic version of the 00 series, so if your is a manual shuttle shift you won't have the secondary filter. but if your is the hydrostatic version it will be located right next to the main line filter, just under where you rest your feet while driving your tractor.
Well if anybody is searching in the future...1 month at the dealership, $1,100 later I got the tractor back with a new hydraulic pump. Seems stupid high to me, but i didn't have much choice. They said it was pumping enough work the steering and 3point but not the FEL.
   / 2400 FEL slow and weak #23
steering is separate section on the pump from FEL & 3 point. FEL requires a little lower pressure but same pump as FEL.
Is the pump all they changed?
That's all they said they changed...said it was only the second pump they have ever had fail on a Branson.
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2008 CATERPILLAR 430E BACKHOE (A51242)
2008 CATERPILLAR...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A51039)
2021 John Deere...
