Marcm157
I have rescued a TC34DA with a 240TL FEL. The tractor sat in a swampy field for nearly 10 years. Got her home and did a complete service. All fluids / filters etc. Did some temporary electrical work and got it running. Greased and lubed everything.
The loader raises but only when pulling the stick partially to the rear. It will not lower unless you go all the way to float. Curl works as it should. The stick feels like it is centering properly but it does sound like the pump is building pressure when centered.
Is there any adjustment procedure for the Joystick? Is there something I can try to further troubleshoot the raise / lower issue?
