25 yr old B7100, what might it be worth?
   / 25 yr old B7100, what might it be worth? #1
plants4u
Puyallup WA
Kubota L2800DT
After 25 years my dad is going to part with his work companion. After all the years and 3,300 hours she still runs good but field mowing or tilling for any length of time in hot weather is too much anymore and it tends to overheat.
So anyhow it seems that a b7510 HSD is the replacement, I'm sure my dad is not going to miss the old girl. So what do you guys think that the B7100 with this many years and hours (worked hard but serviced regularly) is worth? A grand? He's going to sell with the FEL only the implements stay.
Thanks
C.M.
   / 25 yr old B7100, what might it be worth? #2
i would put it on ebay.
if it has a fel it should be worth more than $1000 imo.
you can't buy a tractor like you described that runs in my area for $1000 without a fel.
   / 25 yr old B7100, what might it be worth? #4
On the west coast, I think any name-brand tractor with loader, in condition such that you can put it right to work, will bring over $3,500 minimum. Regardless of cosmetic appearance.
When I was looking in 2003 I never found a Kubota like that under $5,000, and that was for a bare tractor with no loader.
If you put it on ebay, set a high starting bid or reserve, list all known defects honestly, and assume you may have to re-list it a couple of times before it sells. Somebody out there will want it.
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
