It happens to me all the time and it's normal. If you touch the forward/reverse pedals a bit while you're shifting it will go into gear easily - you just need to sync up the gears properly.
Jeff is 100% correct. The gears are not synchronized so you must "line them up" sometimes by touching the hydro pedal. Mine has also done this since new...
Yep...Jdbower has the answer. A SLIGHT step on the go pedals as you are pushing the Hi/Lo lever will give you "click..click" feedback feeling in your hand as the mechanical part of the drive system connects up.
2024 Cub Cadet Ultima ZTXS5 54, 2007 John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
Conversely, if you forget to select a range before you let off the brake on a hill, be SURE to come to a stop BEFORE trying to put it in low or high. Otherwise, you'll grind off a pound or two.
