2520 Headlight coversion kit
/ 2520 Headlight coversion kit #1
crzysnake137
Bronze Member
John Deere 125
I was wondering if it was possible to convert a 2520's headlights to HID lights ( High intensity Discharge) Then blue looking ones or either like Green ons like the color of the tractor. any suggestions are welcome.
/ 2520 Headlight coversion kit #2
Sorry to be a smart a**, but my only suggestion is to save your money:D
/ 2520 Headlight coversion kit #3
This deserves another Bump...:D
/ 2520 Headlight coversion kit #4
Most of the "HID" bulbs are just standard bulbs painted blue or purple (meaning less light to work with). You can take a bulb to your local auto store and see if it's comparable to a standard bulb, but the part number listed is a Deere-specific part. You'd also have a similar effect by trying to find tinted window film for the headlight assembly.
It sounds like you just want this for aesthetic reasons rather than functional ones, but if you actually want a functional upgrade anything beyond 4300-6000K is not a good idea since it's outside the color of light you're eyes are designed to be used with. If you want more light where you need it, look into ROPS-mounted aux lights. Personally I've yet to use the lights for anything other than to use the flashers when I'm close to the road, but I also haven't had to dig out from a snowstorm in the middle of the night yet.
/ 2520 Headlight coversion kit #5
Pimp my 2520, YO ! :cool:
/ 2520 Headlight coversion kit #6
Hey, you know you can get those lights at Advanced Auto and the auto parts stores of that ilk. I at one point wanted to get some higher output light for my rops mounted flashers. Did not give much though on the Headlamps yet. I did upgrade to higher watt bulbs on my 4100 though, but it was a small mod, but it did give mma noticeable increase in light on those cold morning before sunrise in the snow!
/ 2520 Headlight coversion kit #7
I'm assuming that since you specified "high intensity discharge" you are actually looking for a true HID light and not a look-alike for "show" purposes.
If thats the case there are a couple options for you. Deere makes a true HID light as as option on their larger machines, I'm pretty sure this could be adapted to your machine if you added some mounts on your ROPS better check with the dealer though. I think these lights require an external ballast box so there may be some issues with mounting that due to the space required.
A better option may be to use a light from HELLA such as the AS300 or 400 (Hella part # 996242501 12V) that has a built in ballast and is about the size of a standard work light mounted on your ROPS or perhaps fender.
http://cat.hella.com
CAT also makes HID work lights. Theres some good pics there of the difference between light output of halogen and HID too.
Caterpillar: Products>Parts>Operator Environment>Lights
True HID isn't just a coloured bulb as some think it makes a big difference, lots more light and a much longer service interval. Ive installed lots of them on off road equipment, especially woods equipment.
One last option would be to check what kind of bulbs are actually in your headlights (H4 etc) and check on Ebay. There are aftermarket conversion kits available for some types of headlights that may be useable in your factory ones.
Any of these options, except the last one, isn't going to be cheap though. HID is $$$, better count on at least $500-1000 per set.
Jason
i do really want it for show purposes and i know its going to be like that much money what about like a replacement buld this is green led's or just green that what i wanted more?
/ 2520 Headlight coversion kit #9
!! WHAT???
/ 2520 Headlight coversion kit #10
might be easier to find yellow colored replacements--they would still match ;-)
/ 2520 Headlight coversion kit #11
Dont fool with them. there plenty brite enough.:confused:
Dont make your tractor look silly:rolleyes: . Get the tractor first. then worry about
changeing the light bulbs....:D
if you want more light just add the Aux lights from JD on the front
and the back. then you can light up the world.
Chris.....:)
/ 2520 Headlight coversion kit #13
Alright, what's so wrong about modding just for show? I'm getting ready to paint some flames on my Craftsman lawn tractor and that's *definitely* just for show.
/ 2520 Headlight coversion kit #14
At least you have the stuff to mod - this guy dosent, and its years away from happening -not my words, but his
/ 2520 Headlight coversion kit #15
Good point. Now I see his "soon to be" sig. Dream the impossible dream, eh?
/ 2520 Headlight coversion kit #16
How about some spinner rims, low profile tires, L.E.D. under-tractor lighting and a new muffler to make it sound like a buzz saw?
Seriously...
Scott
/ 2520 Headlight coversion kit #17
Ah, the tables turn. On a Saturn owners' forum site I frequent, a much-discussed "mod" is HIR (NOT HID) headlight bulbs. Unlike those fake HIDs, these bulbs really are brighter. And unlike _true_ HIDs, which require significant electrical mods, they plug right in (with a minor trim to the connector) to a typical car's 9006 headlight connector, and fit the 9006 housing socket.
Guess what's a favorite source of these lights? John Deere part # AH211917 . Supposedly used on some old 8000 series tractor. jdparts.deere.com still lists the number, but draws a blank when you follow "where used".
Now I wanna put one of those absurd park-bench-shaped spoilers on the back of my KK brush hog....
/ 2520 Headlight coversion kit #18
I am still considering adding a turbocharger for real.
