2520 lift
/ 2520 lift #1
duster74
Whats the dif with independant lift. and mechanical lift and how do they each work and witch one is better for mmm mowing
/ 2520 lift #2
The mechanical lift uses the three point hitch arms to raise and lower the mower deck, the independent lift uses a hydraulic cylinder. Which one is better depends on you:
Benefits to mechanical:
Cheaper
Will hold the mower at the set height without a separate dial, the independent lift will leak down unless you set the mower deck height dial
Easy access lever control, the independent uses either the loader joystick or a user-mounted lever (this can be a benefit to the independent if you don't like the 3PH lever positioning).
Doesn't conflict with JD Backhoe, the independent lift must be completely removed (four bolts and a handful of hairpins)
Doesn't conflict with loader, unless you add a diverter or another valve the independent lift will steal two of your SCVs.
Benefits to independent:
Can control deck height without affecting 3PH arms, useful if you don't want to take the mower off for some jobs or if you have a 3PH mounted spreader or if you use a bagger.
It's cooler.
It's an excuse to add another set of control valves as a project.
I'm happy I got the independent lift because it forced me into a project where I learned a lot about hydraulics, but really the independent is probably a better solution for most except that it's not quite as elegant. If you intend on getting a grapple or plow you'll probably want another set of mid SCVs anyway so you can ignore the issue with the loader. The backhoe issue is probably 15 minutes of work to change to the BH, not an issue since I rarely need the hoe. Especially with Pat's EZ Hitch installed my 3PH would hit the MCS bags when mowing with the mechanical lift kit (which I used to own), now that's less of an issue. Was it worth the extra money? Probably not to most people but this is a fun hobby to me. If I farmed for a living it wouldn't be cost-justified even if you ignored the loss of value because I traded my working mechanical lift for a new independent lift.
There's lots of opinions on this, you can try searching for "independent lift" or "mech lift" and see what pops up.
/ 2520 lift #3
"Can control deck height without affecting 3PH arms, useful if you don't want to take the mower off for some jobs or if you have a 3PH mounted spreader or if you use a bagger."
Incidentally, JD Lockup Kit, part number LVB24962, allows you to lock the MMM at any height, and still use the three-point hitch for other things. It consists of a couple of brackets that bolt to the rear fender braces and a couple of chains and turnbuckles that connect the brackets to the rear ends of the mower lift arms.
/ 2520 lift #4
Yes, I just looked at that Lockup kit and it is like over $100. You can buy a couple of pins, clevises, and turnbuckles at the hardware store and have the same thing for about $12. I didn't need this on my 4100 tractor because you could just let the mower lift kit drag on the ground when using stuff on the back. You can't do that with my 2520 lift kit or you'll destroy the crossover bar on the lift kit. So if you ever plan on doing any work on rough ground with a 3 point implement you gotta have a lockup kit. This should come with the tractor in my opinion.
CAT 953 4-in-1 Bucket (A68134)
CAT 953 4-in-1...
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
136" BULLDOZER ROOT RAKE (A65056)
136" BULLDOZER...
GENERAC MOBILE...
