2520 & PTO Chipper
/ 2520 & PTO Chipper #1
larry8818
Bronze Member
John Deere 2520
Hi Guys,
I am wondering about the capability of the 2520 and a rear PTO Chipper. I have a 72" MMM on my tractor and for as being underpowered for mowing, it's not...cuts tall grass in low range going uphill at full speed in a single bound!
I was wondering if anyone has any experience with a Bearcat 73554 that they have used on a 2520? The Bearcat has a 5" capacity and I am interested in hearing if that is too much for the 2520. I have seen that model at a local JD dealer on a 3520. My dealer said it will go right on my machine. Thanks for all whom post.
/ 2520 & PTO Chipper #2
I've got a DR 4" chipper/shredder and the 2520 doesn't even flinch, you should be fine with the Bearcat I'd imagine. Enjoy the top discharge, that's one thing that I don't like about the DR. :)
/ 2520 & PTO Chipper #3
larry8818 said:
Hi Guys,
Who in their right mind would dare say the 2520 is underpowered? :D
As for the Bearcat - it looks like it can handle it no problem - but I cant find the suggested PTO rating for that unit -
/ 2520 & PTO Chipper #5
Hi:
I have run a DR 4" chipper/shredder (Rated 19-45hp) on my 2305 and it runs like a champ. (Except for having to jump the seat safety switch).
I don't think you'll have any problem with a 5" chipper on the 2520.
/ 2520 & PTO Chipper #6
Larry - welcome to tbn - you might want to try the search function - I posted a review of the bearcat 73554 used on my TC18 (18HP, 14.5 PTO) - a 4" dry hardwood branch will stall it after about 5feet if you don't stop it from feeding (either precut the bigger stuff into more bite sized pieces or pull it back when the motor slows down). Great chipper.
Here's my review ChipZilla
Doug_Norman also has one - his review here Bearcat Chipper Review
/ 2520 & PTO Chipper #7
MY 2520 spins my DR Chipper like nothing. It only takes 4.5 inch wood, but the only way to make the motor work is to chip dry-hard woods. Anything green goes right through even at 4.5 inches.
Our 2210 powered the DR chipper pretty well too, but this 2520 has been SMOKING the belt on the DR, so its got way more torque.
Don't hold back, get that chipper, because power is not lacking.
/ 2520 & PTO Chipper #8
My 4010 with 18.5 engine hp runs my MacKissic chipper with up to 3.5" limbs with no problem at all. The power requirement goes up by the square root of the diameter. So, a 5" chipper should only require 22 engine hp, assuming the same engine/PTO ratio for the 2520 vs. the 4010. Should be the case for any HST tractor (same engine/PTO ratio).
I've NEVER bogged the MacKissic on the 4010 at all. With a 12 hp Gravely, I'd bog a similar MacKissic on it (no chipper; no shredder) and frequently bogged a TroyBilt with 8 hp engine on up to 2" limbs.
Your 2520 could probably even drive a Jinma that takes up to 6" limbs. A friend of mine has 3 JDs, and he ran the Jinma on his smallest 25 hp model.
Ralph
/ 2520 & PTO Chipper #9
The specs say it would be a good fit. That chipper weighs 720 lbs, so you'll want weights on the front (maybe the loader will be enough).
How much is the dealer asking?
Thanks for the posts guys.
Roy, my dealer is asking $4,275. Seems like alot for an implement without a motor or hydraulics. The dealer said he ordered it for a gentleman whom ordered it for a 2305, because Bearcat told my dealer it would work. Well, my dealer said it does not work on a 2305 and because of that the gentleman walked from the deal. Now the dealer has been stuck with this unit since last fall.
How much have some of you other Bearcat owners paid?
/ 2520 & PTO Chipper #11
"Well, my dealer said it does not work on a 2305"
Did he give a reason why it wouldn't work? I suspect the 3PH doesn't have enough lift capacity (680 lbs) for the chipper.
Your 2520 does, however
$4300 for that chipper does seem high (I would have guessed $3600), but chippers sure do hold their prices! I looked at a rusted out Goossen that I would have paid $700 tops. The guy wanted $1500 firm.
/ 2520 & PTO Chipper #12
Your dealer doesn't happen to be Rozencrantz, does it? $4,275 is the MSRP. I looked at that unit - it's been sitting out all winter. Flywheel & chipper knives were all rusted. A few branches thru it would probably clean it up, but maybe you can rangle for a discount.
The unit is Heavy with a capital H - it would be too much for a sub compact to lift.
I got mine for $3,875 at MB tractor, but I think I got some kind of deal. He originally quoted me $3,600 which was a steal compared to Rozencrantz, but turns out they had the wrong price in the system. He offered it to me "at cost" - I'm sure he still made a few bucks as they stock that unit (not special order) and I find it hard to believe his normal markup is only 10%.
I will say this - after fighting with my WW grinder all the time it was $4k well spent. If you want the shredder part - you won't find a better machine - I checked them all out. If you want to go chipper only, check out the Wallenstein BX42 - (MB stocks them too) a nice unit for ~$2,600.
/ 2520 & PTO Chipper #13
As a bit of a sidetrack to the discussion -- how on God's green earth can they charge so much for the PTO driven chippers? Just the other day I visited my local DR shop (needed to get parts for my DR brush hog), and asked about pricing for the PTO driven chipper -- it was around $2,500 with the chip chute.
Just for comparison, the DR chipper equipped with a 13HP motor and the axle, wheel, other stuff was about the same amount of money! For that matter, it was about the same price as the (superbly built and extremely heavy-duty) DR brush mower with the 15HP Kawasaki engine!
Now the PTO-driven chipper was nicely made, but did not seem ESPECIALLY heavy-duty. About the same gauge metal as the other models. But again... no engine, engine controls, axle, wheels, etc. Is a simple PTO connection worth that much?
Just wondering...
Hey Hazmat,
Yes Rosenkrantz is my dealer. They have never claimed to be the cheapest.
The unit does seem very rugged.
/ 2520 & PTO Chipper #15
Not to try and take over the thread or anything but can anyone suggest a decent chipper for a 2320 that isn't going to set me back a fortune?
I am sick of burning brush and that will all come to a screeching hault once someone sees me from the road. Turns out they would rather have you pay to send it to a landfill. Shhh don't tell anyone.
Thanks,
Mike
/ 2520 & PTO Chipper #16
What are you looking to spend? My chipper/shredder was about $4k, but a chipper alone is about half the price so if you can bypass the shredder you can save a bundle. I live in New Jersey near a swamp, so some nice Italian gentlemen offered to subsidize my purchase, apparently they like tossing ketchup bottles in there for fun and forget to hose it off afterwards - I don't ask questions :eek:
You can also check the Attachments forum, there's an active chipper thread there now and probably a ton more back a few pages.
http://www.tractorbynet.com/forums/attachments/
