2520 w/29 hrs hydrolic leak help
   / 2520 w/29 hrs hydrolic leak help #1
PLUMBER
Bronze Member
Fairfield county , CT.
JD 2520
Just finished mowing the lawn ,dissconnected on ramp deck parked tractor in garage went to garage to get beer later and saw a puddle of oil on the floor ,thought maybe i did nor connect one of the coulpler correctyl but they were fine , the oil is comming from the juction block that the hard piping from the fel outlets is connected too , checked fittings for tightness all were tight , sprayed with simple green after removing tire and rinsed with hot water , looked like it was comming from the alen head bold but it was fine , what it looks like to me is there is a small hole in casting that the oil pees out of when you curl fel has anyone else had this problem , great tractor otherwise /forums/images/graemlins/confused.gif
   / 2520 w/29 hrs hydrolic leak help #3
PLUMBER,
Call you dealer. That is a defect that I'm sure will be quickly taken care of.
   / 2520 w/29 hrs hydrolic leak help #4
PLUMBER,
   / 2520 w/29 hrs hydrolic leak help #5
It's more likely leaking around a fitting and wicking its way around. The source of hydraulic leaks are sometimes very hard to see. Either way it's a job for the dealer under warranty.
   / 2520 w/29 hrs hydrolic leak help #6
2006 GMC Sierra Service Truck, VIN # 1GDJK34D66E175177 (A54865)
2006 GMC Sierra...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A55745)
MCELROY 500 SERIES...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
2006 Nissan Xterra SUV (A55853)
2006 Nissan Xterra...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
CATERPILLAR 126" PIN ON BUCKET (A52707)
CATERPILLAR 126"...
