2520 w/29 hrs hydrolic leak help
   / 2520 w/29 hrs hydrolic leak help #1
PLUMBER
Fairfield county , CT.
JD 2520
Just finished mowing the lawn ,dissconnected on ramp deck parked tractor in garage went to garage to get beer later and saw a puddle of oil on the floor ,thought maybe i did nor connect one of the coulpler correctyl but they were fine , the oil is comming from the juction block that the hard piping from the fel outlets is connected too , checked fittings for tightness all were tight , sprayed with simple green after removing tire and rinsed with hot water , looked like it was comming from the alen head bold but it was fine , what it looks like to me is there is a small hole in casting that the oil pees out of when you curl fel has anyone else had this problem , great tractor otherwise /forums/images/graemlins/confused.gif
   / 2520 w/29 hrs hydrolic leak help #3
PLUMBER,
Call you dealer. That is a defect that I'm sure will be quickly taken care of.
   / 2520 w/29 hrs hydrolic leak help #4
PLUMBER,
   / 2520 w/29 hrs hydrolic leak help #5
It's more likely leaking around a fitting and wicking its way around. The source of hydraulic leaks are sometimes very hard to see. Either way it's a job for the dealer under warranty.
   / 2520 w/29 hrs hydrolic leak help #6
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
1996 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
1996 POLAR TANK...
John Deere 333G Track Loader (A53485)
John Deere 333G...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
