2520 water seperator sight "glass"
   / 2520 water seperator sight "glass" #11
The water separator bowl on my 2320 engine is clear enough that you can see the filter and the red ring inside. However, there is no drain valve on the bottom of the bowl. One must remove the entire plastic bowl to drain and recycle the contaminates. I put the small amount of fuel I get from the bowl into my used oil container that I take to the recyclers.
My sales guy dropped in today on his way home and we were talking about the fuel seperator not being easy to see through. He said they just got in the replacement 2520 and it's like mine.
He did mention again that a couple years back that the ones on all JD tractors had a clear plastic, Hopefully on Friday I'll have the time to call JD about this one and take a pic for you guys too. ;)
   / 2520 water seperator sight "glass" #13
Yep, my 2210 has a nice glass-clear plastic bowl. It is also located outside of the engine shrouding so it's easy to see at a glance. Maybe you could re-adapt the 2210 bowl.
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2018 GENERAC MAGNUM PORTABLE DIESEL LIGHT TOWER (A51247)
2018 GENERAC...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
6" & 12" CHANNEL IRON UP TO 23 1/2' LONG (A51247)
6" & 12" CHANNEL...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
