2520 with hydraulic fluid leak?
   / 2520 with hydraulic fluid leak? #11
Post pictures of that project when you can - sounds like a solid project
I already had plans to post pictures from start to finish. It has been a quality job so far, just alot of work. I have not had the time to complete everything. After the hours I have logged I got the backhoe on lockdown. Things really picked up once I learned to move myself still sitting in the back seat with the backhoe. Once I figured that out it saved me alot of time from having to jumping back and fourth to move the machine. On the bright side of this job I caught a **** of a tan.
Took a bunch of photos so should get a couple good ones that give a good idea.
Here is a quick photo to give you an idea.
   / 2520 with hydraulic fluid leak? #13
gunmaker said:
Well I got mine back from the dealer, and she's working like new again. They told me that it was a crushable copper washer that failed, and that it was covered under warranty. I checked the service manual, and found that there are torque specs for those fittings. Probably a factory oversight. I am gonna call the service mgr back and confirm that it was a copper washer, because the service manual describes "O" - rings. So maybe the leak wasn't precisely where I believe it to be. Soooooo- still have questions.
I believe an oring is part of the copper washer. That is where my 2320 was leaking from as well. I think they get overtightened at the dealers and this causes the o-rings to blow. I could be blowing hot air, but after looking at my machine, that's what it looked like to my eye.
   / 2520 with hydraulic fluid leak? #14
I have a jd 2320 w/ a 46 back hoe. I bought it 6 months ago and have less than 20 hours on it. I am taking back to the shop for the 3rd time for the same hydrolac leak. It is coming from the valves and leaking all over the frame.
   / 2520 with hydraulic fluid leak? #15
JDCAN said:
Anyone with a 2520 having any issues with hydraulic fluid leaking?
I got 40 hours on the machine and I notice small amounts of hydraulic fluid leaking on the right rear side of the tractor.
I am hoping it is a small fix to save me from visiting the dealer, if anyone experienced anything along these lines on a 2520 would love to hear it.
The first 3 hours on my 2520 I was plowing snow with the FEL and one of the fittings began to spray fluid on the hood and on the snow. I called the service guy who instructed me to make sure the fitting was tight which turned out to be the problem. Easy fix and he even delivered 2 quarts of fluid to me that day.
   / 2520 with hydraulic fluid leak? #16
Those copper washers on mine failed at 36 hours. The inside diameter of the washers is too big. I got some with a 5/8" ID and 7/8" OD they fitt better and won't distort as easily. I replaced all 8 copper washers on the 4 banjo fittings that go into the valve. I hope this helps someone out so that they don't dump hydraulic oil all over their garden like I did.
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2006 International 7400 Dump Truck (A47477)
2006 International...
