2538 50-hour service is how much??
   / 2538 50-hour service is how much??
Negative. I actually had all the rear attachments off of it. I thought it was excessive too but figured that was their way of recouping some of the cost of the taillight lens. Can't say too much since they have been good to me in the past.
   / 2538 50-hour service is how much?? #12
You definitely got burned. :money: Whats the story on the taillight. Is this something you did or was it like that upon delivery? :confused3:
Probably something I did. I noticed that with my Speeco Quick Hitch installed that it would sometimes hit the black plastic taillight housing when it was all the way up. That and vibration I'm guessing caused the mounting studs to break.
I have removed the quick hitch since it's not compatible with several of my attachments now. Going to get a set of Pat's easy change links in the not too distant future.
   / 2538 50-hour service is how much?? #15
Did they bill you for the light?
   / 2538 50-hour service is how much?? #16
Should have asked for your air filters back....
   / 2538 50-hour service is how much?? #17
   / 2538 50-hour service is how much?? #18
If you do your own 50hr., could it jeopardize the warranty?
   / 2538 50-hour service is how much?? #20
If you dont do the service correctly yes... keep a log and use exact fill capacities youll be fine
202474 (A54757)
202474 (A54757)
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55315)
2019 Krause...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
