2555 Cab front turns/hazzard LED's
   / 2555 Cab front turns/hazzard LED's
Do you know what LED lights you used for the work lights? Did they come with a bracket or is that the oem one?
I bought these 36 watt floods... mounted using the stock steel mounts. The lights came with aluminum mounts, which I discarded. That's the weak link in a lot of the LED work lights. Some don't hold up to vibration over a long period, whilst the lights themselves seem to last. I put some round 27 watts on my 5035, and ended up fab'n up some heavier mounts when the supplied ones started cracking. These light fit the notches in the 2555 roof, but you have to add longer 8mm bolts and space them out a little if you want to point them more horizontal in the front ones. Good luck...!!!
4pcs 7inch 36W CREE LED Work Light Bar Flood Offroad Lamp 4WD Boat ATV Truck SUV | eBay
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
John Deere 54" Blade (A50774)
John Deere 54"...
