jmh1783
A few weeks ago we had a week of rain followed by freezing weather. A week ago I went out to start the tractor to clean snow off my driveway. It wouldn't start. The engine barely turned over. I tried a few times and the power kicked out completely. No dash lights. I got out a charger and a very long extension cord and let it charge. When I put the charger on, it said 66%. That seemed suspicous but I let it charge.
A returned a few hours later and gave it a go. It turned over a little better but it still sounded like a dead battery. It shouldn't be I only have 175 hours on the tractor. I turned the key to off and was surprised that the gauges didn't go off. I got a strange ticking sound from under the dash. The tachometer moved erradically and the fuel gauge didn't return to E. I cranked it again and after about two turns it cut out and went dead. I played with this several times and finally got it to crank enough to start. It ran fine.
I warmed it up, cleared the snow and moved it into the barn. I think there must have been water in one of the contacts somewhere under the dash to have caused a short. I got out a space heater and heated up the barn the following day for a few hours. I did it again the next day and tried to start it. No problem. It turned over readily and started immediately.
I decided to go looking so I took off the dash to see if I could see any connections that might be vulnerable to water intrusion. There are a couple facing upwards. Nothing jumped out at me. I suppose the problem could be under the hood. I didn't look there. I really need to remove the loader to do that. Any thoughts? I'm thinking I should apply some dialectric grease to all the contacts.
