2615 4WD won\'t start
Just went out and cranked the tractor to let it warm up while I took the kutter off. I intended to put the boxblade on and clean up some around where I burned a brush pile earlier this week. It cranked fine like it normally does, but after running about 2 minutes, it started coughing white smoke and died. Now it won't start. Just puffs white smoke when the starter turns the engine.
It has about 1/2 tank of fuel, the oil shows right at the full mark, and the radiator is full of pretty green fluid. It only has 43 hours on it. I pulled the air filter, and it looks OK. It was pretty dusty, but not so much that I'd think it's starving for air.
What's this sound like, guys? I did put about 2 gallons of fuel in it since the last time I ran it. This was fuel that was left in a 5 gallon can since the last time I filled up, and I suppose it could have gotten some moisture in it, but I don't think so. The fuel filter at the back where the line comes out of the tank looks pretty dark, but I couldn't tell much about it.
Should I drain the fuel that's in it, add fresh fuel and try it again. Or, just wait until tomorrow and call the dealer? Like I said, it has 43 hours on it and I was planning to have the dealer come get it for the 50 hour service soon. So, if draining the fuel doesn't work, I may go ahead and have them come get it.
What say ye?
Thanks,
BR
What say ye?
Thanks,
BR
