2615 with a john deere model 48its hoe
   / 2615 with a john deere model 48its hoe #11
Galen
Again thank you for your time ,I think I understand now ,I cant use a Tee due to this would allow the pressure to bypass circut.so if I just follow everything back from the P/B port I should be fine. But if I understand right I can Tee into my return for the the fluid to return to transmission?
Dan.S
Yes you can T the return line.
Here is a picture of the mount or cradle. The guy I bought the backhoe showed me how he uses the 3pt arms to sit it in the cradle and its obvious John Deere designed it this way but after reading your post I know your right it would be easier to let the stabilizer arms and the bucket sit it to the proper height and then just lowering it in my cradle. Thanks again.j
Here is a picture of the mount or cradle. The guy I bought the backhoe showed me how he uses the 3pt arms to sit it in the cradle and its obvious John Deere designed it this way but after reading your post I know your right it would be easier to let the stabilizer arms and the bucket sit it to the proper height and then just lowering it in my cradle. Thanks again. Well lol I just figured out I can't post a picture from my phone.
Gallen
Thanks again for your help ,your advice helped me very much.
I just have to finish welding the cradle hooks to the subframe this evening and i should be digging . Hydraulics went just as you discribed .
As far as the subframe I used 2x4 1/4 wall tube and attached to front loader mounts ,then attaches to rear axle with 8 bolts ,from there it is bolted to the drawbar mount . So im hopeful that multiple mounts should help tranfer the digging forces across the tractor and not just one point. Anyway thanks again for your time and patience with me. Oh and please buy another snowmobile next year so we will have another warm winter lol..
Dan.Steward 317-512-0188
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2013 Ford Focus Sedan (A50324)
2013 Ford Focus...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
377672 (A51573)
377672 (A51573)
