2710/2910
   / 2710/2910 #11
For $875 I would go for the 2910. There weren't no such thing when I got my 2710. The telescoping links would be worth it.
Now if someone would come up with an easy way to hook up the PTO shaft I'd pay $8000 for that.
Alan L., TX
   / 2710/2910 #12
Someone did come up with an easy way. On several tractor makes (i.e. the Ford and a David Brown of my dad's) the operator can freely rotate (as in around and around, very little resistance) the pto shaft by hand when making the connection. Now you want to be careful doing that, for the cautious ones (not me admittedly) you could turn the tractor off. Allowing it to turn freely makes a hookup so much easier, rather than trying to horse the equipment pto shaft. Of course, I am only familiar with an L3010DT, maybe the other models allow you to turn the shaft. While turning it just a bit by hand to get the splines to line up would be easier, the hydraulic clutch on my tractor can be bumped to get the splines to line up. The control lever location makes this fairly easy, but not as easy as just turning it a few degrees by hand.
This is an annoying thing to me. Perhaps they do it specifically to keep people from grabbing the pto shaft when the engine is running. Properly designed and turning sufficiently freely, you don't have to grab tight. A thumb and finger can turn either of the 2 pto shafts I referenced above.
On another issue, the telescoping sway bars also annoy me. They allow as much as an inch of sway at the tips of the lift arms, which correlates to 5-6" out at my mower. When I am in close to something, when the wheels caster it occasionally bangs into things. That David Brown has simple solid bars that goes in the same place, but rigidly attaches at both ends on pins much the same as the end of a lift arm. That system is ROCK solid. It won't move an 1/8" inch. Much simpler and cheaper. But this telescoping is 'user friendly', a piece of crap, though it may be. I agree that every once in a while a bit of slop in the system is handy when you bang into something solid, but if the slop is already taken up for some reason, this safety factor is negated.
'Nuff venting. Really, other than these 2 minor issues, I love my tractor.
Farmer kid usetabe, Farmer Wannabe
   / 2710/2910 #13
MDNick, it's very easy to turn the PTO output shaft on my B2710 to line up the splines for hooking up implements; I do it all the time. That's easier than trying to turn the driveshaft. And you're right; I might be overly cautious, but I don't hook up (or unhook) a PTO driveshaft without shutting the engine down.
Bird
   / 2710/2910
Glennmac,
After I get the tractor, I hope to be able to change my bio from <font color=blue>"10 acres, mostly brush and rocks"</font color=blue> to <font color=blue> "10 acres, mostly cedar chip mulch and gravel"</font color=blue>! /w3tcompact/icons/laugh.gif
Thanks to all so far. I count one neutral and four positives. Any negatives? Does the slop MDNick talked about in the 3010's extendable link arms also occur in the 2910?
   / 2710/2910 #15
Just a quick clarification. I do not have extendable link arms. Only telescoping sway bars. These keep equipment on the 3 point from swaying back and fourth. The slop in them comes from various swivel locations, the pin holding the telescoping parts not being perfectly sized (even if it were, it will wear eventually), etc. I have just seen better systems on a 1974 tractor and at the sake of what some may see as convenience, we have given up system rigidity. I don't like things swaying back and fourth AT ALL. The only exception being plows (not blades). Plows need to float back and fourth a bit. There is the potential for FAR to much strain on the system if they didn't.
Where this is a real issue is post hole diggers. That digger can flop around 6+ inches just on sway. Much more difficult to nail dead center of a future hole with that much slop. Call it a pet peeve of mine. Unfortunately, you get used to it. Doesn't mean you have to like it.
Nick
   / 2710/2910 #16
Fishman,
A year ago almost to the day I faced the same decision you are now facing. Which way to go? I chose the 2710 because I thought the $1,000 "savings" would look better to my wife. Especially since I started telling her that the 2410 would be perfect for me. Well,,,I now wish I would have faced the wrath of my wife and gotten the 2910. I have added a weight suspension seat and as I buy more implements the extendable lower links would be really nice to have. Maybe in 10 or 15 years I'll be able to talk my wife into trading up, but for now I am very satified with the 2710, as my wife tells me almost everyday. Hope this helps!
   / 2710/2910
Rbrown,
Hey, that describes my situation exactly. I, too started with the 7500, and quickly convinced the wife that the 2410 was "perfect". Now you see where I am at./w3tcompact/icons/laugh.gif
As someone who has used both the 2710 and the 2910 style seats, what is your take on them? Obviously you liked the weight-distributing feature enough to pay for it specifically, but what about it is different? I have not seen one in person, only the 2710 which was just great. Thanks.
   / 2710/2910 #18
To all,
Doesn't all newer gear-drive Kubota tractors have built-in overrunning clutches? If so, doesn't this mean that the the PTO shaft should always turn freely in one direction?
Kelvin
   / 2710/2910 #19
I moved the pto portion of this thread to 'owning'.
Nick
2016 Chevrolet Malibu Sedan (A53424)
2016 Chevrolet...
2017 FORD F550 XL SUPER DUTY BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
