2800/3400 brakes
   / 2800/3400 brakes #11
2 gallons of fluid, and nothing changed? It's a bit perplexing that your tractor would run if that depleted. Did you lower all implements (FEL, arms on 3ph) before looking for a bubble in the sight glass? Me, I see nothing in that glass when the FEL and 3ph are elevated, but everything zeros out fine in the "down" positions. I'd be REAL sure my system was depleted before adding any more fluid. When I got my first hydraulic fluid change, the sight glass looked empty - I called the dealer. Now, the fluid is a light tan.
   / 2800/3400 brakes #12
Let me preface this by saying I am totally unfamiliar with that tractor.
That aside, at least one poster says you have mechanically actuated wet brakes, not hydraulic ones, which is in agreement with my experience with tractor brakes on older machines. I have never had one with hydraulic brakes.
Operating on the presumption that your system is mechanical and based on your description of the conditions under which they quit operating, I'm pretty sure you caught something in the linkage and have a part jammed or disconnected somewhere. Get under the tractor and have someone else move the brake pedal. Watch the linkage to see if everything moves all the way back to where the linkage disappears. Look for stretched, bent, or disconnected parts. If everything appears normal, consider a trip to the dealer to do the same thing on a new tractor and look for any differences.
The worst case I can think of is that a branch snagged a part of the linkage and bent or broke something internal. I think it is most likely that it broke something external -- there is usually an intentionally weak link in a complex mechanical linkage, like a shear pin on an outboard to protect the engine when the prop hits a rock.
Good luck and let us know what you find.
Like I said, this is based on zero familiarity with your machine, but experience with assorted mechanical systems.
   / 2800/3400 brakes
you are correct about the mechanically actuated wet brake system.thanks for the info.i went to the dealers today and looked under another l2800 and i found that i had bent the rear bracket that holds the adjusting rod and nut sideways.i bent it in such a way as it looked perfectly factory distance and appeared factory fresh.returned home pulled the bracket off straightened it out and presto new brakes again.
thanks to all you guys for the input and glad their is such a wealth of knowledge here for us newbys.oh and i did have to drain out the 2 gallons of fluid i had added as i did indeed overfilled because of the clear fliud.
thanks again
vulcan
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
Adams 5 ton Fertilizer Buggy / Wagon (A52748)
Adams 5 ton...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
Swict 78" Bucket (A50121)
Swict 78" Bucket...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
