2920 with 72inch MMM
   / 2920 with 72inch MMM #11
How do you find the extra weight when removing / installing on the tractor?
No significant difference really. They're both kind of clumsy to move around -- they don't always go where you want them to when you push. I have a blacktop driveway, so it's not been too hard to move either one of the mowers underneath the tractor (I pop up the front end with the loader -- don't use the "drive-over" feature). I don't know, maybe it would be more of an issue on a softer surface or gravel...
I asked about the cost of the 72" when buying and the difference was just too much at the time - was more than half the cost of the 60" mower itself. Did you get a reasonable trade in price?
Yea, this was more of an issue. Since I'd used the original 60" deck for a while, I took a bath on the trade-in. I had to give something like another $1200 IIRC for the upgrade. The dealer had to come and get my tractor, uninstall the old deck, and install the new deck. Probably could have saved some money if I did that myself. Unfortunately, I didn't ask for an A/B comparison on my package price when I originally bought the tractor/FEL/MMM. That would be a better indicator to go by.
I justified it by knowing I'm going to keep the tractor for a long time and use the mower for many, many hours. Amortizing the extra expense over the life of the tractor made it hurt a little less. And, it made me happy :laughing:
One thing I do notice about the difference between the decks: the 72" is definitely heavier rolling on the ground than the 60", and I think it leaves more ruts in soggy/muddy areas than the 60" deck did. Another small thing: the 60" deck left more "patterning" in the cut grass than the 72" deck does. IIRC, it has a couple of wider anti-scalp rollers that push the grass down in a particular pattern. The 72" deck does not show this effect.
   / 2920 with 72inch MMM #12
I started with the 60" MMM on my B3030, but quickly went up to the 72" RC72-30B.
The extra foot makes it easier to mow around fence lines and get closer to obstacles. Plus, mowing the pasture goes a little faster (diesel is expensive). It's great for flat areas, but I probably wouldn't recommend it if you have a lot of slopes, hills and uneven areas to maintain. The extra width hurts in that case.
When you say "mowing the pasture", how much acreage are you mowing? I am interested in the same setup you have (B3030 with 72" MMM) but wasn't sure how it would handle clean and clear pasture land (as opposed to using a rotary cutter). I would like the cleaner cut of the MMM if it works well for this.
Thanks!
Rob
   / 2920 with 72inch MMM #13
Thanks!
Rob
Well, it's not much of a "pasture" really -- I use the term loosely. It's only about 4 acres, no obstacles, gentle hills. It's really more like an extension of my yard. The previous owners of my place put a vinyl fence around that area for horses. It was a little overgrown when I bought this place, but after a few mowings with a bush hog, I got it under control. Since I've had it under control, a finish mower has been working fine out there. The area is a bit too rough to mow with my lawn tractor. That was one of the reasons to justify my purchase of the B3030.
Sorry, I don't have any experience mowing a REAL pasture. Just old farmland that's been turned into my little hobby pasture.
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
Caterpillar Loader Quick Coupler (A55218)
Caterpillar Loader...
flooring (A53424)
flooring (A53424)
2018 FORD F150 XL TRUCK (A51406)
2018 FORD F150 XL...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
