2955's Topless Now Questions
   / 2955's Topless Now Questions #11
The 2955 does have the same transmission pump setup. I can't say I would recommend replacing it if you have no symptoms. Those pumps are pretty reliable. The pressure line from that pump has been known to break though. If you decide to make the extra split(between clutch housing and transmission) be sure to check the pressure pipe and elbow at the pump. There has been an upgraded line, fitting and clamp that takes the stress off of the line that was causing it to fail. Not sure, but all the 55 series may have the better line. I think the 50 series were the ones with problems in that area.
My buddy's had the bad lines, and that was the main problem. He said they are notorious for going out/leaking if you are close to 5000 hours.
Doosan P250 Trailer Mounted Air Compressor (A53117)
Doosan P250...
2025 Swict 78in Bucket Skid Steer Attachment (A51691)
2025 Swict 78in...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
2003 Ford Ranger XLT Pickup Truck (A51692)
2003 Ford Ranger...
