2x6 or 2x4 walls?
   / 2x6 or 2x4 walls? #11
Code requirements aside, I'd recommend you spend a couple hrs and do a little math, cost Vs benefit analysis. Cost of added materials today, lumber and insulation Vs reduced energy costs. Don't forget to include likely increases in energy costs over the yrs and the possibility of some tax credits for being more energy efficient. If the payoff on the added cost is less than 10 yrs, I'd go for the added cost today.
You should be able to get most of the info needed for this little exersize from the lumbr yard and power Co(s).
   / 2x6 or 2x4 walls? #12
Jay,
Code considerations not withstanding.....You might want to consider 2x4 if you use a high R-value insulation such as sprayed on foam. You would yield R-24 or so with foamed-in 2x4 walls. You would have a nice tight easy to heat/cool house. If you go that route install and air exchange system too, else you'll be breathing stale air all the time.
~paul
   / 2x6 or 2x4 walls? #13
I am a framer of high end custom homes. My opinion (for what its worth) is to use spray foam and 2x4 walls. That is if you are having 8' or 9' ceilings. We do a lot of 10' ceilings, and I would use 2x6 there for strength. I question just how much advantage you actually get with conventional batt insulation going to 2x6. I know it says the R value is higher (and it is) but the weak link is still there -AIR MOVEMENT!!
Jason
   / 2x6 or 2x4 walls?
Thanks for the input!
For sound considerations, the area we are in is extremely quiet, and if there *IS* any significant noise outside, I probably want to know about it!
There are very, very few code requirements in this area; they've only recently added septic and electrical permitting, so it's not likley that any code would require 6".
I really like the extra strength consideration, and the ability to go with R-19 insulation. Like Dan, we'll also have lots of glass area, so the extra insulation to help offset that might be the deciding factor.
We have a probable GC/builder in mind (just finished my BILs house), so I'll check with him regarding cost differential, both for materials and for framing labor. I can't see where additional labor would be much of a factor, but with the ever-increasing cost of lumber, 2x6 cost may be a significant factor. Anyone have any recent data on cost difference that I can cross-check against the builder?
- Jay
   / 2x6 or 2x4 walls? #15
I sure wouldn't count on a lack of wind in your area. Tornadoes and severe thunderstorms can pop up anywhere. :( We used 2 X 6 walls with brick on top of that for all of the reasons others have stated. No regrets. Can't imagine you'd be unhappy with six inch walls. Four inch? Maybe.
   / 2x6 or 2x4 walls? #16
We built two years ago and the 10' and over walls are 2x6s. We could of upgraded them all, but our builder talked us out of it. As most (75%?) of the heat loss is up, the walls are a small part. Then if you realize that the windows are the weak link in heat loss to the sides, then the R values of the walls has a very small impact. I ran the numbers (with very large SWAGs) and it wasn't worth the extra for 2x6s.
But what do I know...
   / 2x6 or 2x4 walls? #17
When I built my log cabin I used mostly 2x4 framing for interior walls but used 2x6 framing on walls that had plumbing in them. Just made it easier.
   / 2x6 or 2x4 walls? #18
Egon said:
Check your codes. There are some places where 6 in. walls are mandatory.:D
The above is the very first thing one does before designing and/or laying out a home or any other type of wooden building.
Most areas are now requiring you to use 2X6 outside wall framing for all energy savings. All parts such as door, windows and other parts are now made and easy to get for both the 2X4 and 2X6 walls. The initial costs are a bit higher, but the savings makes up for it in a very short time. Pay back is around 5 years and from there on it's all savings. Don't forget to go with the double insulated windows and doors. Again in most areas this is also required by code. :) As stated in the thread below about using 2X6's on interior wet walls is also the most common thing to do.
The Gotcha Man
   / 2x6 or 2x4 walls? #19
Jay,
I forgot to mention we have 10' ceilings. Helps in the summer but hurts in the winter. :D
I highly recommend the books by Joe lstiburek. He is an engineer who has books with design details depending on one's climate. He has a website at Building Science Corporation
The wall details in our house are from one of his books.
Later,
Dan
   / 2x6 or 2x4 walls? #20
Around here it is code to go with 2x6 exterior walls. Just didn't know there were that many places where people are building 2x4 stick houses any more. Just not sure what the savings would be using the 2x4 wall structure.
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
Fiberglass Cow Statue (A55218)
Fiberglass Cow...
