3 cylinder diesel freeze plug removal
   / 3 cylinder diesel freeze plug removal #11
i always use a 5/8 bolt and a pipe wrench to remove the plugs
I tried removing it yesterday with a 3/4" drive socket, a 3/4" strong arm and a 4 foot long cheater pipe but could not budge it. So will give up for now and just use the lower radiator hose heater once the correct size one arrives later this week 1-1/2". Have not tried to put the coolant back in yet since I already cut the radiator hose. The 1-3/4" one proved to be too big.
Will not know until then if the core plug is leaking. If it does I will take more drastic measures to get it out.
Any suggestions?
   / 3 cylinder diesel freeze plug removal #13
I doubt if you damaged anything by beating on it. You could try an impact wrench if you have room get on to it, or maybe some heat with a torch around the outside of the plug.
   / 3 cylinder diesel freeze plug removal #14
IF it leaks.. I'd use the impact wrench idea.. however most of these plugs are virtually one with the block after being CI on CI in water for 40ys.. :)
Got the coolant back in it and the engine up to temperature and no leak so far from the core plug so I think I am good to go. Won't try that again.
   / 3 cylinder diesel freeze plug removal #16
good to go!
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53473)
Kuhns AE10 Small...
1992 SHOP MADE CHASSIS TRAILER (A53843)
1992 SHOP MADE...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
