3 point drops
/ 3 point drops #11
sounds to me like you have a bad valve somewhere. are you saying soon as you touch the handle it drops.
/ 3 point drops #12
Do you not have an UP, neutral, lower on your lever?
/ 3 point drops
I am in the city at work and cannot access that now, but I know it is a B6200E. 2 - wheel drive. Gear, not HST. It was originally set up with a belly mower which operated off a front PTO. With the belly mower, it did not matter because the wheels on the belly mower were adjusted to the mowing height desired. Now it matters. I'm now using the rear PTO with a small rotary cutter. The lever is somewhat like a toggle. To the rear and it raises the implement. Forward and it drops it. It does not stay in either position. It goes back to neutral automatically. It is also right next to my hip when operating, so it can easily be bumped without noticing and change the height of the implement.
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
Rhino DB150 (A57148)
2018 HINO SA (A58214)
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2020 MACK GR64FT DAYCAB (A60736)
2020 MACK GR64FT...
