3 point hitch hose and Leaky Joystick
   / 3 point hitch hose and Leaky Joystick #1
madhatter
Sherwood Park,Alberta,Canada
2015 Massey GC1710
Well, finally blew my first hose on my 2006 gc2310. It was the 3 pt hitch/backhoe hose. Looks like it wore thru by rubbing and got pinched. Will need to route it differently. Off to Goodall for a new one, except it is saturday and they are closed.... :(
Figured I would fix the leak on the loader control as well. Hopefully just an o-ring. I see others have changed this so will tackle this at the same time. Is it a imperial o-ring or metric ???
   / 3 point hitch hose and Leaky Joystick #2
You did well to go this long! I've had to replace two on mine so far, an '07 model. First one was two years ago, IIRC. Sorry, can't help with the o-ring; haven't been there yet.
reason I had to replace a hose was due to the 3PT hitch. Happened the first month I the tractor. scuffed the rubber, finally gave out. At the same time I replaced all the rear hoses. New ones are dual braid, same size. Overkill yes, but I wanted to re-route all the rear hosesanyway, so good time to replace them. All three rear cost $90.00 and that was brand name double braid. Even got them to replace one with a 45 degree ( backhoe return hose ) as it was a very sharp bend from the tractor.
kENWORTH TMA (A55973)
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A57453)
2006 GMC W3500...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
New Wolverine 84in 5way Skid Steer Scrap Blade (A59000)
New Wolverine 84in...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
